True Duals
Old Aug 4, 2011 | 10:15 PM
  #31
Tek74's Avatar
Tek74
Improved Looks
Improved Sound
Less Heat
Very minimal (if any) loss of bottom-end Torque
Enough Said
Old Aug 4, 2011 | 10:22 PM
  #32
bwana1's Avatar
bwana1
I have a question or all the "low end torque" aficionados. At what RPM range are you referring to for your low end torque?
jus wonderin'
Bwana
Old Aug 4, 2011 | 10:31 PM
  #33
TCannon22's Avatar
TCannon22
A stage 1 download is a very simple upgrade with no tuning ability.. It just is what it is.
My 88" fatboy had a stage 1 a/c, stage 1 download, and I changed the pipes on it several times.
Trust me when I say there was a very noticeable, not dramatic, but noticeable loss of torque when I put on a set of V&H true duals. I put on V&H sideshots and V&H pro pipe and the bike felt noticeably stronger. No dyno required.
However...
If I had the SERT, a PC, or some similar tuner where I could have had the bike tuned properly with the true duals, I feel like the difference would have been much more insignifigant.
Apples to apples.. stock head pipe vs. only true duals, you will most likely feel a loss in torque but nothing too dramatic.
true duals vs. a good 2-1 on a stock motor, you will feel a more noticeable loss in torque.
Stock headpipe on completely stock bike vs. true duals with a stage 1 A/C and a tuner, you will definitely not feel any loss of torque.
Throw a good 2-1 on that same bike with the stage 1 A/C and a tuner, you will feel more torque than with the true duals.
Anyways.. that's my .02 cents.
slow night at work..
Old Aug 4, 2011 | 10:35 PM
  #34
TCannon22's Avatar
TCannon22
jus wonderin'
Bwana
Me personally, I noticed the bike struggling a little more under say 2500-2800 or so. Seemed like it took longer to get to 3K on the tach from an off idle roll on.. but once the bike hit the 3K mark there was little to no difference in how quick the RPM's climbed to redline.
Old Aug 4, 2011 | 10:43 PM
  #35
danmo's Avatar
danmo
Going from stock TC88 to a TC88 with Stage I and true duals I didn't lose low end. It's nice losing the heat on the right side and the sound is quite nice. Oh, and they look good too.
Old Aug 4, 2011 | 11:52 PM
  #36
Mike's Avatar
Mike
Originally Posted by mkguitar
We are talking "pipe vs pipe", not "stock vs stage 1"
no, we're not. The OP has a "completely stock" bike, and is considering putting on true duals, and the usual chorus of "you'll lose low end torque" is the immediate response.
If you're saying that true duals will have a later torque band than some 2-1 systems, then that's what you need to say, not "yup, loss of torque".
Old Aug 5, 2011 | 12:07 AM
  #37
jeff.georgalas's Avatar
jeff.georgalas
A+, one of the most intelligent statements I've heard here yet!
Old Aug 5, 2011 | 01:09 AM
  #38
Mike's Avatar
Mike
I've been running true duals on my bikes since the mid 60s, and wouldn't have it any other way. I almost put a fatcat on my bike this year. One had dropped into my lap for next to nothing earlier this summer, but I just couldn't bring myself do it, so I sold it to a friend. He's happy with it, and I'm happy for him. I'm not getting rid of my Rineharts.
Old Aug 5, 2011 | 02:01 PM
  #39
fxdxrider's Avatar
fxdxrider
My experience of where the dip is shows that it was below 2500 rpm - around 2300 (and which basically can be made extinct with a tune anyway). This is pretty close to the "lugging" zone. Anyone who "loves torque" and rides their bike at 2300 isn't getting as much torque as they would at 3500 (where a stock Harley is maxing out) so I'm not sure what they're really looking for. Maybe they actually "dislike downshifts". I tend to ride through the 2500 point to around no lower than 3500 and then shift - obviously higher if I want to get a move on. So even if I had a dip I wouldn't be in it. And I'd like to point out that at 3000 rpm I'm making 100 lbs with TD's and a fairly mild basic bore and cams set up and I realise that a 2-1 would get me a few more lbs but it's no slouch believe me.
Old Aug 5, 2011 | 03:40 PM
  #40
mkguitar's Avatar
mkguitar
no, we're not. The OP has a "completely stock" bike, and is considering putting on true duals,....
Boo, You are correct about the OP.
my response which you quoted above was for a rider who mistakenly may have compared "stock" to "stage 1", with his "stage 1" using TD's.
- Just uncorking the intake and mufflers will add 7 to 10 HP which is inline with what he saw.
--- To anyone ( most of us) who are happy with your pipes, for whatever reasons, fine.
However, some systems have drawbacks which the marketing department doesn't advertise.
Make the buyer aware- just so he knows.
Mike
