04 Road King issues
Old Aug 10, 2011 | 06:23 AM
crobo_us's Avatar
crobo_us
3rd Gear
Default 04 Road King issues
Hey All,
Love the forum. Most helpful for a new ie like me. One question for my brother. He has an 04 Road King purchased about a year ago with approximately 17,000 miles on it. It is fuel injected with Vance and Hines duels exhaust.
Bike runs great until after shutting down for has or a break. After starting. Joe does not idle well and will backfire and abut off. Have replaced the plugs and air filter but still experiencing the problem. Any help or advice would be most appreciated.
Old Aug 10, 2011 | 07:52 AM
mrmud4x4's Avatar
mrmud4x4
Any codes show up?
First thoughts are idle air control (IAC) or the throttle position sensor(TPS).
Old Aug 10, 2011 | 08:11 AM
user 29711972's Avatar
user 29711972
Was the air cleaner changed with the exhaust? The higher flow exhaust without higher flow air intake caused lots of backfiring in my 06 FLHRI. However, it wouldn't stall...
Old Aug 10, 2011 | 08:48 AM
crobo_us's Avatar
crobo_us
3rd Gear
Wow, im obviously out of my league. Not sure about air filter change along with exhaust change, that was done by previous owner. As far as codes...how would you determine these. Were would the readout be? Again, sorry for my ignorance in these matters and thanks for all the help and patience.
Old Aug 10, 2011 | 08:53 AM
user 29711972
The air cleaner should be easy to determine...if the black plastic backing (about the same size as the chrome cover) is gone and you can put your fingers right inside the chrome cover, it's all but certainly been changed. I supposed someone could remove that and not change the filter, etc, but that would just be silly.
Old Aug 11, 2011 | 02:22 PM
mrmud4x4's Avatar
mrmud4x4
engine light on should let you know if there are or were any fault codes.
I think with an 04, maybe have to jump some plug wires to be able to read the fault codes. Harley dealer can do it.
I have a powervision and can see my codes with that...if you know of someone with a powervision...they can look at your fault codes too.
Search codes on forum.....there is info on this out there.
JemEO
Apr 26, 2019 08:11 AM
Tj92
Mar 22, 2016 09:59 PM
Ultra103
Aug 3, 2013 08:30 AM
Marquezj16
Sep 30, 2011 10:49 AM
cpersson
Apr 22, 2009 10:47 PM
