Final drive locking tool
Old Aug 13, 2011 | 08:35 PM
RK_RIDER's Avatar
RK_RIDER
Default Final drive locking tool
Has anyone used V-Twins final drive locking tool on a 2007 touring sprocket.
It is less expensive than some of the others, I was just wondering if will do the job.
Old Aug 13, 2011 | 09:28 PM
Beemervet's Avatar
Beemervet
A piece of flat bar stock will do the job..............
Old Aug 13, 2011 | 09:37 PM
RK_RIDER's Avatar
RK_RIDER
I gave lots of different methods a try but not a piece of flat bar stock they all became bent twisted or broken trying to remove the nut.
how would the flat bar stock method be set up I am willing to give it a try.
Old Aug 13, 2011 | 09:38 PM
18BKLR's Avatar
18BKLR
I think it is something like 5 and 7/8's long. Round the edges. You can make one for a few bucks at a hardware store. 1/4 inch flat bar about an inch and a half wide or so.
Old Aug 13, 2011 | 09:45 PM
soft 02's Avatar
soft 02
Yep, used one yesterday no problem. Gotta love home made stuff. I cant believe MoCo sells that stuff. In my old tractor service manuals it would give you specs for special tool so you could make them yourself.
RK_RIDER's Avatar
RK_RIDER
I think we have a communication problem the tool I am talking about mounts on to the final drive pulley. I have already made a tool to remove the primary drive sprockets/clutch/compensator.
Old Aug 13, 2011 | 09:53 PM
soft 02's Avatar
soft 02
Yep thats it. Took a piece of bar stock and threaded a hole in it. then a bushing a little shalower than the pulley then a shorter piece of bar stock with a hole in it. Install a 3/8 bolt till its tite on the pulley and lean it on the frame. Is that what you were talking about?
Old Aug 13, 2011 | 10:13 PM
RK_RIDER's Avatar
RK_RIDER
sounds like you are in the right area,but I must be real tired as I don,t understand how you are mounting this to the pulley
Old Aug 13, 2011 | 10:22 PM
soft 02's Avatar
soft 02
Mine pinches the outside of the pulley. Not exactly the OEM tool but I have used it several times and it works well. I machined the parts with a mill to get the tolerences right.
Old Aug 13, 2011 | 10:39 PM
RK_RIDER's Avatar
RK_RIDER
Thanks,
Soft02 but I tried a pinch method similar to what you are describing and had no luck removing the nut it would rotate off the pulley.
