Looking for advice on the correct way to replace it and pads at same time I don't have a service manual and don't want egg on my face(LOL)07 ultra classic electa glide
If you're going to be doing that kind of work the very first thing you should have is the service manual. There are torque specs and such that shouldn't be overlooked. To change the rotor you'll need to pull the rear wheel and reinstall. If you do all of this incorrectly you could end up with more than egg on your face.
Get the manual, check it out and if you have questions then come on back and ask away.
There is a way to do it without removing the wheel. Its in the manual. You have to remove the two 1/4 inch bolts that hold the pads in place for this you will need a 1/4 inch 12 point socket. then compress the pistons remove the pads and install new ones. Just remember which one goes on which side as they are different.
Subject title says "rear disc replacement". One would have to assume he is referring to the brake rotor which requires removal of the rear wheel. In his thread he talks about also replacing pads which does not require wheel removal.
took your advice MANUAL is on the way what size are the bolts holding on the cal.
Caliper is held on by the axle. The pad pins are 1/4" 12 point.
Rotor bolts are T40 torx and are installed with Loctite. Use a propane torch and heat the center of the bolt head to soften the Loctite. I've broken bits before I learned this.
Yes,,, there is a way to replace the disc without removing the wheel . It's been done So many times You don't need to be a rocket scientist You just need the right tools
You need to pull the axle back to get the rotor off. At that point you might as well drop the wheel. It would make it much easier to work on removal/install of the rotor
The savings you will make doing this yourself, compared with having a dealer or indy do it, are so much you will cover the cost of a factory service manual several times over. Doesn't matter how much your local dealer charges for it, smile and pay up. Don't buy any of the cheap copies. Get the parts book as well. Then we can help!
