Python Baffle removal
Old Nov 15, 2006 | 12:28 AM
SCS's Avatar
SCS
Default Python Baffle removal
I have Python slip-ons on my 06 Ultra. They sound great but I want a little more sound. Does anyone know how to remove the baffles from slip on Pythons. There are 2 small screws under the pipes but when I loosened them, the baffle didnt seem to move at all. Theres gotta be a trick to this I'm sure. Also I have the download and stage one kit installed but Will I have to do anything else?
Old Nov 15, 2006 | 08:23 AM
wnogood's Avatar
wnogood
Default RE: Python Baffle removal
After you get those 2 screws out, pull real damm hard on those baffles, they will come out, but they are in there tight. I use to have a set and had the baffles out several times.
nogood o~`o
Old Nov 15, 2006 | 08:56 AM
SCS's Avatar
SCS
Since i already have the download and stage 1 kit , will it do any damage to the motor running without any baffles at all?
Old Nov 15, 2006 | 05:03 PM
wnogood's Avatar
wnogood
1st problem.....it will sound like $hit
2nd problem.....Yes, it will seriously lean out your fuel mixture.
3rd problem....did I mention that it will sound like $hit?
nogood o~`o
Old Mar 21, 2012 | 11:20 AM
brummie's Avatar
brummie
Default Baffles
I have the same pipes.. with a dealer download, and high flow air filter...I have not had them on long, they sound OK ..but a lot of popping when de- acceleration.. I may go back to stock...do you have this problem..If anything I might put in a longer baffle brummie
Old Mar 21, 2012 | 05:47 PM
Tinman265's Avatar
Tinman265
I have the same pipes too.... I tried the quiet baffles and it was a chore to get the standard baffles out and even harder to get the quiet baffels out....
I ended up drilling a small hole in the top of the baffle and hooked the baffle with something of substance and used a claw hammer and a block of wood on the tip and pulled them like a nail....... have fun getting them back in and lined up so the screws go in.....
Mine are extremely loud so I wrapped the baffles with the ceramic baffle wrap.... That made it even more fun to get back in....
I have a 103 with true dual headpipes and my mufflers are the newer style with the scalloped ends.
Old Sep 7, 2021 | 02:03 PM
pearlultra13's Avatar
pearlultra13
Stage I
Anyone ever try to cut the baffle down about half way?
Curtis629
Oct 24, 2021 12:11 PM
Keith821
Sep 19, 2009 10:51 PM
ScooterGuitar
May 17, 2006 08:53 PM
Tn.Heritage
Exhaust System Topics
Mar 23, 2005 11:08 PM
