Abs flashing light
Old Aug 22, 2011 | 06:00 AM
walterhess's Avatar
walterhess
Stage IV
Default Abs flashing light
I just installed a set of anarchy wheels on my 2011 RGC. everyhting thing went fine in the re- assemply I believe i followed all the instructions in the big book, but now I have the flashing ABS light on. i took the bike on a 5 mile run and the light stayed on any suggestions ???
Old Aug 22, 2011 | 06:13 AM
cochon's Avatar
cochon
There are special ABS wheel bearings. Did you put them in and if you did, did you put them in correctly???
Old Aug 22, 2011 | 06:34 AM
laduckslayer's Avatar
laduckslayer
The ABS sensor at the connection is not the strongest. Check this first. I had this issue and had a hell of time finding the issues. Good old backwards engineering was my friend on this day.
Old Aug 22, 2011 | 07:54 AM
Bfazona's Avatar
Bfazona
I had a similar problem with my wheel install, turned out that the wrong bearings were installed from the wheel manufacturer. Also, the ABS bearing needs to be on the correct side as the sensor. The ABS bearing is usually grey in color.
bsdoig
Apr 10, 2019 03:18 PM
super48
Mar 4, 2017 09:03 PM
what_the?!
Mar 9, 2015 11:44 PM
Dundlux
Nov 19, 2013 03:00 PM
norris
Mar 12, 2013 04:11 AM
