New Guy Here
Old Aug 26, 2011 | 10:58 AM
1BBA's Avatar
1BBA
6th Gear
Originally Posted by hdelectra
I too would go with the '09 for the reasons listed above (frame, larger tire, exhaust improvements, etc), if you can get them to come down some.
Is it that the lowers & tour-pak are removable or are they gone to never be seen again?
I'll tell you, when I had my '05 EGC, I removed the tour-pak because I hated it, hated the looks of it, etc. Turns out, at the end of it all, I rode with it ON 95% of the time. Just sayin!
I spoke with the dealer and the tourpack and lowers are just gone I most likely would just get some engine guard chaps for the winter time riding. Thanks for the input
Old Aug 26, 2011 | 11:00 AM
old_mikee's Avatar
old_mikee
I'm siding with KCFLHTK, but either one of these are reasonably priced.....
Welcome to the world of Harley and good luck with whichever you select...
mike
Old Aug 26, 2011 | 11:11 AM
Dr.ultra2010's Avatar
Dr.ultra2010
welcome from HOT SPRINGS,AR
1BBA's Avatar
1BBA
6th Gear
Thanks for the quick replys, I can't wait to leave work problem is I don't leave until the 8th of Sept. so all I can do is drive myself crazy looking at bikes until then.
Old Aug 26, 2011 | 11:19 AM
acd118's Avatar
acd118
Welcome aboard. Go with the '09 like the other guys said. Revised frame, bigger rear tire, newer year so it is worth a tiny bit more. Mileage is virtually the same so that doesn't even matter. Same motor and trans so that doesn't matter. Both are excellent bikes, so it will ultimately come down to you. But if it were me, I'd do the '09. Good luck
Old Aug 26, 2011 | 11:24 AM
gred-04's Avatar
gred-04
Hey from AL.
09+ gets my vote for the frame improvements as well.
Just my opinion but for 17k you should be able to find a 09 that is not
missing the pak and lowers. Then you can remove and have them
around should you need it.
I know that doesnt seem important now but as another guy who first
went stripped down I now ride with pak on all the time. Just to convenient
to use for storage.
If you do any touring you will want it and it will cost about 2k to add that
stuff at a later date.
Best of luck on whatever you choose.
Synenberg
EVO
57
Oct 28, 2014 02:02 PM
asm481
Jul 15, 2012 04:41 PM
okieblue62
Mar 20, 2010 04:43 PM
peewee97
Jan 22, 2009 01:14 PM
skb_35
Aug 26, 2008 01:31 PM
