Quick - Urgent question about front forks
Old Aug 27, 2011 | 04:15 PM
dz1087's Avatar
dz1087
Default Quick - Urgent question about front forks
Do I have to take out the bolt at the bottom of the shocks in order to get the tubes out? I'm trying to change the seals, and the allen bolt at the bottom is almost stripped out. So at this point, I'm going to have to get a mechanic to extract it if I have to take that bolt out in order to remove the tubes.
Old Aug 27, 2011 | 04:29 PM
bubbabear's Avatar
bubbabear
Yes. You do.
Old Aug 27, 2011 | 04:32 PM
dawg's Avatar
dawg
Yep, 6mm allen bolt can be a PITA to remove. air impact usually takes it out.
Old Aug 27, 2011 | 04:37 PM
Stiggy's Avatar
Stiggy
And if the bolt is stripped too badly, you can drill the head off, remove the leg and the bolt with pliars and replace with a new bolt upon assembly.
I've never removed them sucessfully without an air impact gun.
Old Aug 27, 2011 | 04:41 PM
Beemervet's Avatar
Beemervet
I've never sucessfully removed them sucessfully without an air impact gun.
That's it. No mechanic needed.
Old Aug 27, 2011 | 04:48 PM
dz1087's Avatar
dz1087
How big of a bit are we talking here? Never done this before.
Old Aug 27, 2011 | 05:10 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Get a service manual...... it's not a one time shot. You will need it for other things too.
Old Aug 27, 2011 | 06:08 PM
fabrik8r's Avatar
fabrik8r
Just as big as the bolt head or a little bigger, but small enough to fit in the recess in the fork. The allen recess will serve as a pilot, almost can't do it wrong, aproach it good and straight, go easy till the head comes off, dont want to drill into the fork, but the bolt material will keep it from just digging in once you get through the head, no worries if you exercise a little caution.
Old Aug 28, 2011 | 08:26 PM
dz1087's Avatar
dz1087
Got both of them off fine. And yes I have the service manual, I was just not straight on if I HAD to take that bolt off. Thanks for the help guys.
sledgeb1
Apr 30, 2023 03:01 AM
scooper321
Wheels/Tires
24
Feb 11, 2018 09:31 AM
maverickwolfe
General Topics/Tech Tips
May 28, 2015 10:57 PM
SDNightster
Jun 18, 2014 11:53 PM
Scarz
Nov 29, 2012 10:26 AM
