1 to 3" lowering kit
Old Aug 28, 2011 | 08:34 AM
kent11's Avatar
kent11
Stage I
Default 1 to 3" lowering kit
i installed a lowering kit for my 2011 streeglide
.dropping it only 1" and nnow im feeling a weird vibration when i twist hard on the throttle or hit bumps.i checked my air pressure in the shocks it was 0 P.S.I well ! i put about 20 lbs in the shocks i hope this fixes it.
anybody put these type lowering kits on? it has 4 holes
Old Aug 28, 2011 | 09:39 AM
vtwinbob's Avatar
vtwinbob
i have the tamarack lowers on my 10 ultra and they dropped it 1" also, i run 42lbs on mine and don't have any vibration, having no air in the shocks don't help it, just make sure you don't have a leak and check them often. mine seems to need a couple lbs. of air every 4 or 5 days.
Old Aug 28, 2011 | 09:41 AM
geezer glide 56's Avatar
geezer glide 56
Did you check your drive belt tension?...Chances are your belt is too tight.
Old Aug 28, 2011 | 10:04 AM
buggy's Avatar
buggy
I also have the tamarack kit,It changes the shock angle so the ride will be a lil different and yes the belt gets tighter. I run about 35 psi in mine ,but I notice when I hit a bump the wife bitches more when the kit is on the bike and more important I cant rip a wheelie with the kit on.
Old Aug 28, 2011 | 10:07 AM
mkguitar's Avatar
mkguitar
-- and be aware of 2 things
reduced cornering angle
possibility of tearing up the rear light wiring inside the fender if the tire bottoms out.
mike
Old Aug 28, 2011 | 10:25 AM
baust55's Avatar
baust55
i looked into lowering kits when i got my 2008flhrc but found most or all would not work with the leatherwrapped bags. so i had the seat modifyed buy MeanCity Cycle , nose narrowed seat lowered 2.5 inchs .. with memory foam option .
Old Aug 28, 2011 | 04:52 PM
buggy's Avatar
buggy
The 09 and up do not have the wireing in the fender . 08 and older do .
luckyOne
Mar 29, 2015 10:03 AM
tom_sprecher
Oct 23, 2012 03:14 PM
marvo75
Feb 28, 2012 04:43 PM
BrendanGTStang
May 8, 2007 09:16 PM
dchoran
Jan 2, 2006 12:47 PM
