help with front brakes
Old Aug 31, 2011 | 02:36 PM
bigirn's Avatar
bigirn
Default help with front brakes
i cracked a front rotor and replaced the rotor. the cracked rotor messed up the front calipler so i had to rebuild it. the problem now is i can not get the front master cyclender to pump up. it worked fine before i have pulled a vacum rebuilt the thing and also tried pumping the fluid back up to the master cyclender from the calipar still no luck. im stumped as to why it wont work when it was working fine before. any ideals as to what might be the problem.
thanks
Old Aug 31, 2011 | 02:39 PM
69cj's Avatar
69cj
thanks
Would help if we knew what bike and year your talking about. ABS, no ABS etc.
Old Aug 31, 2011 | 02:52 PM
bigirn's Avatar
bigirn
its on my wifes 90 softail singel disc 5/8 bore . i no this is not the right forum but this is the one i hang out in.
again thanks for the help im stumped as to what to try next other than a new one. but like i said it worked fine before
Old Aug 31, 2011 | 03:15 PM
bigirn's Avatar
bigirn
bump
Old Aug 31, 2011 | 03:49 PM
hojones's Avatar
hojones
Sometimes it takes a while to get it to pump up. I have had the same problem on differant bikes. Try taking the caliper off again and with the piston side pad use a c-clamp to fully compress the caliper piston. Hold the piston in with clamp and pump it up and bleed it. It should pump up. The master cylinder has such a short stroke it is not moving a lot of fluid. Hope this helps.
Old Aug 31, 2011 | 05:33 PM
Alabamaslammer's Avatar
Alabamaslammer
What he said. I had to do that on my 1981 shovel just about everytime I took the rear wheel off, but that was the old banana caliper
Old Aug 31, 2011 | 08:04 PM
bigirn's Avatar
bigirn
thanks for the enfo guys ill give it a shot in the mornin.
Old Aug 31, 2011 | 08:27 PM
steelerdude1's Avatar
steelerdude1
Try bleeding it at the banjo bolt first, then move on to the bleeder valve. That has worked for me in the past when I had a stubborn brake.
Old Sep 1, 2011 | 10:28 AM
bigirn's Avatar
bigirn
Question
here is the up date. pulled the calipar of the piston was still closed. pulled the brake lines off blowed air through them to make sure they wernt cloged. took master cyclinder back apart. put it back together. with my finger over the hole i slowly pumped short strokes just enough to see air bubbles. and then it wont bubble anymore there was no presure on my finger. ive taped the handel slightly pulled in with the bleeder open and leting it sit. also tried taping on the bottom of master cyclinder to see if any more bubbles come up.
maybe its time for a new one
Old Sep 1, 2011 | 10:39 AM
bigirn's Avatar
bigirn
here is the culprit me and the wife at the stone house sallon in Wyoming. 1500 miles one way from W.V. lucky the rottor held out till we got home.
