I know you have a 96ci motor but I wanted to show you what Jamie at FuelMoto did with just a cam change. He's working a new Woods cam into an 88ci motor and his 88 is making more power than a stock 103: https://www.hdforums.com/forum/touri...e-testing.html
Heard a lot of good things about the FM 107 kit. My dealer even says good things about them. Just for an example my dealer is doing a 103 kit complete with true duals for $3100. 110+ hp and 115tq. He says its more reliable than new. I have a friend with this build and it runs like a scalded ape and the motor is as quiet as a stocker. They travel on it constantly and have no problems.
Well a big bore kit without cams is limited to stock cams. I'd go with cams first. Then if not enough add the big bore kit. There are some quick cammed 96 bikes out there. My two cents...
