Big Twin Neutral Rattle
Old Jan 7, 2013 | 07:49 PM
  #61
David Browne's Avatar
David Browne
6th Gear
Will the nuetral rattle occur when riding and in gear and iddling down?????
Old Jan 7, 2013 | 08:10 PM
  #62
g money's Avatar
g money
Account Retired
Motor hot, clutch pulled in, in neutral. Noise comes from the right side, under the clutch cover.
Old Apr 19, 2013 | 11:28 AM
  #63
Cliff-AZ's Avatar
Cliff-AZ
I have it too. Noticed it starting around 3k mi. Now at 3300 and its pretty loud and embarrassing. Seems as if it got louder after replacing my cams and headers.
I think the slightly added vibration made it worse.
I will try the heavy gear oil. Right now it has the 20W-50 Synthetic from the 1k service.
Old Apr 19, 2013 | 08:06 PM
  #64
Ultra Pearl's Avatar
Ultra Pearl
I don't get it in my 08 in neutral, but get it in first gear when just moving really slow with the clutch just bearly engaged in low rpm's
Old Apr 19, 2013 | 09:34 PM
  #65
SteveMKentucky's Avatar
SteveMKentucky
Isn't the clutch on the primary side on the left?
Old Apr 19, 2013 | 09:35 PM
  #66
SteveMKentucky
Originally Posted by ixlr8
Have any of you heard a dry clutch Ducati?
Yup. Have one. Different issue. The Ducati sound comes from the clutch design. The Harley rattle apparently comes from the gearbox, specifically the gear backlash.
Old Apr 19, 2013 | 09:41 PM
  #67
SteveMKentucky
Originally Posted by txfxstrider
... I wait at stops in first.
Then you're causing abnormal wear to your clutch release bearing. The whole time you're sitting there the release bearing is grinding away.
As an aside, VW received a large number of complaints of clutch release bearing failures on the beetles that they began exporting to the U.S. They didn't have the problem in Germany. The VW clutch release bearing at that time was a solid carbon block. They sent an engineer to the U.S. who discovered that Americans sat at lights with their foot on the clutch. VW began fitting roller bearings on their U.S. export cars. Apparently Europeans knew to only depress the clutch long enough to change gears.
Old Apr 19, 2013 | 09:56 PM
  #68
SteveMKentucky
Delete please...
Old Apr 19, 2013 | 09:57 PM
  #69
SteveMKentucky
Originally Posted by kingbee
Its not the clutch your hearing. Noise is coming from under the "clutch release cover", right side. Read post number 1
I'm not hearing anything. I'm referring to the quoted post.
Old Aug 4, 2013 | 09:33 AM
  #70
timbo141's Avatar
timbo141
Originally Posted by dawg
HD put out service bulletin M1304 for all 07 and later twin cams which states:
"When a motorcycle is at operating temperature and in neutral, a rattling sound may be heard on the right side coming from the area of the transmission side cover. This sound is normal and is referred to as neutral rattle. To verify the sound is neutral rattle, pull in the clutch lever and hold it for 10 to 15 seconds. If the sound stops, it is neutral rattle. Neutral rattle is caused by the necessary backlash within the first gear pair."
Thanks for the update, but if your bike doesn't have the rattle, does that mean you don't have the necessary backlash within the first gear pair?
I had all the bearings replaced in the trans and primary along with a new compensater. Bike is like new now, smooth as ever but now has the neutral rattle.
