Changing Tires.................
Old Sep 10, 2011 | 01:34 PM
Jinks's Avatar
Jinks
Originally Posted by SpiderPig
Get one of these and never use a tire iron again. Works absolutely fantastic! http://home.comcast.net/~prestondrake/mojoweb.htm
Couldn't agree more since that is exactly what I use, but the "motorcycle wheel adaptor #42927" isn't available any longer. Makes the used ones fairly valuable........
Old Sep 10, 2011 | 06:22 PM
nchogfan's Avatar
nchogfan
I use the guy operating the tire changer at the local indy shop!! LOL
Old Sep 10, 2011 | 07:21 PM
oasis03's Avatar
oasis03
Fort Thunder in Moore Ok. quoted me 100.00 to mount and balance my tire with my wheel off of the bike. Sounds tike a good time to invest in some tire equipment.
Old Sep 10, 2011 | 07:34 PM
69cj's Avatar
69cj
My indy charges 20 bucks to remove the old tire install the new and balance. Not worth me messing with it.
Old Sep 10, 2011 | 07:47 PM
SpiderPig's Avatar
SpiderPig
Go to your local junk yard and get a 14" steel wheel. Turn it upside down and set your tire and wheel assembly on it.This will allow you to work on your wheel even with the rotor attached. You can line the edge of the 14 wheel with some duct tape for protection so your motorcycle rim doesn't get damaged.. I also use a 3/4 threaded rod through the middle of the rims with some large washers to hold everything down to a handy table lift top. This system works very well.
Old Sep 10, 2011 | 08:10 PM
kmayHD's Avatar
kmayHD
"I use a 20 dollar bill. Hand it to the tech, and problem solved."
Yep sounds good to me too.
SLORider
Product Reviews
45
Aug 29, 2017 07:20 AM
Time Machine
Sep 23, 2015 09:31 PM
WARG
May 4, 2009 05:19 AM
joker1450
Sep 9, 2008 08:50 PM
chaswood
Mar 24, 2008 10:20 AM
