tire balance/ dyna-beads
Old Mar 23, 2008 | 09:47 AM
chaswood's Avatar
chaswood
Default tire balance/ dyna-beads
hi ,has anyone heard of or used these synthetic beads- DYNA-BEADS-that go on the inside of your tire and they will balance your tire???
THANKS
CB
Old Mar 23, 2008 | 09:59 AM
rocknrod's Avatar
rocknrod
Default RE: tire balance/ dyna-beads
I'm thinking of buying this as it does more than one thing for the tire/wheels:
http://www.ride-on.com/prod_mot.asp
"Ride-On is currently sold by six of the nation’s ten largest commercial tire dealers. They install our products into the tires of their commercial customers, who demand that the products not harm their aluminum or steel wheels. As their tires can last upwards of 250,000 miles, the fact that Ride-On is designed to not harm tire ply materials or cause loss of adhesion strength helps those customers retain tires for the fullest life possible. Letters from manufacturers such as Michelin, Goodyear, Bridgestone/Firestone, Continental, Yokohama, and Toyo that indicate that the use of our products do not automatically void their warranties also bears witness to our success in creating a product that does not cause harm to tires or wheels.
Old Mar 23, 2008 | 10:05 AM
chaswood's Avatar
chaswood
hi, do you work for the manufacture of this product.
thanks
cb
Old Mar 23, 2008 | 11:30 AM
Windup08's Avatar
Windup08
I have my tubes of Ride-on fluid just waiting to go in my 08 UC tires once temps come around and I can ride more regularly. Also got some to put in a new set of tires on the wife's 04 Accord. I've been researching this for several months and believe it is well worth a try. With dyna-beads you only get balancing...why not get balancing, cooler running, and flat protection all at once?? And no, I don't work for the company.
Old Mar 23, 2008 | 01:08 PM
Lroberts4's Avatar
Lroberts4
I have been thinking about using this also - keep us updated as to your thoughts/experiences - trip to KY in June, hoping to install before that - road safety!
Old Mar 23, 2008 | 07:46 PM
chaswood's Avatar
chaswood
iHI,
I HAVE NEW RUBBER ON MY RIDE. ONE OF MY BUDS IS GOING TO TRY THESE WITH IN THE NEXT COUPLE OF WEEKS, I WILL LET YOU KNOW. THANKS CB
Old Mar 23, 2008 | 11:39 PM
TXCHOP's Avatar
TXCHOP
I have used the beads on about 8 front tires now. I say front, because it easier to find problems if there is one. I have found they work great if the amount of beads is close to the amount weight it would have needed if done the traditional way. If the tire needs too much weight, than the beads are not that great.
Old Mar 24, 2008 | 10:20 AM
Mississippi Bagger's Avatar
Mississippi Bagger
Been using the dyna-beads, front and rear, for about 5k miles now. They seem to work fine with the Michelien Commanders. Much smoother ride compared to the lops with stick on weights. Of course, I do not know how much is the dyna beads and how much is the tire. [:-]
Scudda
Jan 19, 2013 05:29 AM
mikelikesbikes
Sep 27, 2012 08:18 PM
WARG
May 4, 2009 05:19 AM
tommarbru
Jan 24, 2009 05:42 AM
tweeker
Jul 24, 2007 08:51 AM
