16" / 19" combo or 16" / 21" combo
you can adjust this geometry by lowering the front end 1" - 1.5" to gain some of that change back.
but when doing so, you are going to shorten the stroke of your fork travel, resulting in a less desireable ride.
going a 19" wheel you probably wont gain that much height, im not sure the overall dimension of the 19" wheel tire combo, but i doubt its much more than the factory 18" wheel tire combo.
all this stuff is relative though, because what you might feel is a good/bad ride quality, handling willl differ from others.
for instance i cant stand the stock rear air shocks and needed something that jsut plain worked well in a canyon carving situation. where others feel the stock shocks to a great job.
some say that running the 21" front wheel doesnt change much in the handling area, i for one will say different. the steering is a tad heavier, not alot, but a little, with a 21" front the bike doenst turn in as quickly as with a 18" setup. i notice this alot in my case. i have ran both the 18" and a 21" but not a 19" wheel.
it was a big battle for me to either keep the 21" wheel on or go back to an 18"
no doubt about it a big wheel looks cool and thats just that.. a 21" wheel trumps the look of a 19" it just does. the thing you have to decide is will the slight change in handling/performance warrant the look you want.
i think im gonna be putting my 21" wheel back on, jsut cause it gives the bike so much character, im gonna loose that bit of handling i want, but its a sacrifice i guess for that "look"
Pros : looks bad ***
Cons: slow speed handling changes, bike turns in quicker and you hold the bar back to keep it from dumping rather than pushing it forward to turn (if that makes sense)
16 and 21 -
Pros: looks better than 16 and 16 I guess
Cons: Looks stock, haven't ridden it so no handling comments
If you're gonna spend money on a new front wheel, why go w/ a stock looking 19?
(just as an FYI the 19" set up wether you go 130/60/19 or 120/70/19 are almost identical to the stock wheel diameter)
although all the picture is see of bikes with 21s look good whever is see one in real life it just looks too big.... strangely enough i don't mind it on a Roadie, i think the big fairing balanced out the big wheel (p.s. sweet bike dbell )
my real problem is that i don't think i want an 18" rear...which is a probelm because that means that HD Agitators are out..and thats a shame cuz they are really pretty resonable compared to aftermarket wheels... and they are THE ONLY 19" wheel available that is 3.5" wide...all others are 3"
i'm leaning toward a 17" rear with a 200 tire... IMO the 18' makes the rear of the bike look higher...i don't know maybe its just me. i have aslo read a decent amount on some handling issues with the 18" 200 rear.... though some swear not....
