Stage 1 - Worth the $$$$$ ?
Old Sep 14, 2011 | 05:13 PM
NDBadlands4-2's Avatar
NDBadlands4-2
Default Stage 1 - Worth the $$$$$ ?
I am looking at getting a stage 1 upgrade for my Ultra. Not because it needs more power, or I need more volume. Both are fine. The reason is because I am looking at shedding heat. If I get True Dual exhaust and get rid of the catalyst and put on slip ons it will get rid of a whole bunch of the engine heat and that is what I am after. The thing is quite the furnace and I am looking at cooling it a bit. Has anybody done a stage 1 on a 103 twin cam? Does it help with the heat? Is it worth the cash for the benefit?
Old Sep 14, 2011 | 05:36 PM
PFWiz's Avatar
PFWiz
If you are trying to reduce heat make sure you get ceramic coated headers...
The answer is yes, good ceramic coated pipes with a non epa tune will lower the temps on the right side of your bike noticibly
Old Sep 14, 2011 | 05:42 PM
rooti's Avatar
rooti
To get the engine to run cooler you need to find a way to richen up your fuel mixture.
Exhaust and intake won't really help with the heat and if your happy with the way it sounds and runs you probably won't be happy with the results.
I added XEID's and it brought down the temp about 25-30 degrees and the bike runs better. You can also richen it up with a tuner...it all depends on how much you want to spend.
There is some valuable info related to heat on nightrider.com. The XEID's I bought were 100 bucks and a 15 minute easy install.
Old Sep 14, 2011 | 05:45 PM
shortride's Avatar
shortride
I had a Stage 1 installed shortly after buying my '09 and I think it's worth it to have the engine run a little cooler. It cut the fuel mileage a minimal amount but it was worth it. If I were going to do anything else to reduce the heat it would be to have the headers ceramic coated.
Old Sep 14, 2011 | 05:55 PM
NDBadlands4-2
Ok. Who makes a good ceramic coated pipe?
Old Sep 14, 2011 | 06:03 PM
Chunker's Avatar
Chunker
At my 1K service which the dealer did, I had the V&H naked intake, V&H power duals, SE street performance mufflers, and fuelpak installed. Runs much cooler, good low end torque and not too loud
Old Sep 14, 2011 | 06:11 PM
dulley's Avatar
dulley
Default heat
on mine 2011 r.g 103 i put on the power duals the harly stag 1 air filter and back plate and v.and h. dual tip slip ons and the heat is down and the power is up .lost about 2 to 3 mpg ,and i had the stag 1 down load .,n a friend of mine did his after he seen how mine was and he loves it too.so yes i would do it .you can save alot of money by doing it yourself then let harly do the down load
Old Sep 14, 2011 | 06:33 PM
rlhdude's Avatar
rlhdude
You don't need ceramic coated pipes to reduce the heat... Getting rid of the cat will do most of that.
Old Sep 14, 2011 | 06:44 PM
dulley's Avatar
dulley
Default cats black
yeah when i took my cats off they were dard blue if not black the bike only had 1100 miles on it ,so what does that tell you.i dont get half the heat i had before
Old Sep 14, 2011 | 06:56 PM
bgdv1's Avatar
bgdv1
yep got rid of cats on my 11 SG and my leg doesnt bake any more and the bike has a way better tone out of my SE 4" mufflers
