LeNale fan install
Old Sep 16, 2011 | 09:12 PM
05 Ultra's Avatar
05 Ultra
If I turn on the fan, its because I see traffic coming up. If I'm moving the motor stays right around 200, maybe 230 if I'm going slow. Remember these motors run warm. Don't think there's a problem getting it to burn off any condensation.
Old Sep 17, 2011 | 12:31 AM
myred55's Avatar
myred55
[QUOTE=steelerdude1;8827234]not sure if its the same on an 09, but my 06 has an accessory plug behind the left side cover, by the ECM, and 1 under the seat (which you are using for your Zep)[/QUOTE
What is a ECM?
Thanks
Old Sep 17, 2011 | 09:58 AM
steelerdude1's Avatar
steelerdude1
the plug accessory plug looks like the smaller gray plug in this pic i found on google, mine is black and is tucked behind the fuses.
your ECM (engine/electronic control module)is the big black square with horizontal lines on it. in a nutsell it is the computer on your bike that controls your bike, most commonly modified to change Air fuel ratios when stage 1 air filter and pipes are added
Old Sep 17, 2011 | 10:18 AM
steelerdude1
When I tapped in to a switched wire for my heat demons, I used the orange wire seen under the same side cover (per the instructions) and they work great. so thats another source for power for you.
bladeguy
Electrical/Lighting/Alarm
Jul 14, 2016 08:04 PM
Angelsbass
Mar 14, 2016 05:12 PM
airfuel
2014-2024 Touring Models
Jul 19, 2015 02:37 PM
ReidRik_Von
Dec 19, 2013 04:30 PM
DrPlastic
Sep 25, 2008 08:34 AM
