am/fm trouble
Old Sep 18, 2011 | 11:48 PM
Eric Moore's Avatar
Eric Moore
Default am/fm trouble
I hadnt used my am/fm for so long..the other day I was just tring it out..it would never pick up a signal..like the antenna wire was off..so i started checking all the connections.. had the fairing off.... found nuttin wrong.. finally tracked down the antenna wire dowm..it was cut into right next to the rear tire.,.. well I run a 17 x 5.5 with a 200mm rear tire.. the wires were routed along the fender & was rubbing ... after replacing the antenna cable I rerouted it to give it more room..those 200 mm rear tires are close..so if your running 1 check your wires near the tire..I even found the light below the tag..(red light) was rubbed..so I repaired it..I soilder them & used heat shrink over the joint...just thought I'd pass along this info...
Old Sep 19, 2011 | 12:03 AM
mkguitar's Avatar
mkguitar
________
just plain john
Audio Systems
Sep 26, 2014 06:30 PM
jevans66
Audio Systems
Aug 20, 2014 08:26 PM
fwb35
Jul 13, 2012 07:25 AM
HarleyArcher
Aug 18, 2008 09:20 AM
agapsdiver
Nov 2, 2007 11:03 PM
