Oil Loss
Old Sep 20, 2011 | 06:41 AM
beaver07's Avatar
beaver07
Stage III
Default Oil Loss
Hey Guys First time threader so go easy on me. I resently purchased a 2007 street glide and road it to Colorado, 1700 miles into the ride I checked the oil to find it was a half quart low. Is this normal. thanks
Old Sep 20, 2011 | 06:55 AM
Schex's Avatar
Schex
Most people run them halfway between full and add, keeps oil out of the a/c.
Old Sep 20, 2011 | 06:56 AM
Bodean46's Avatar
Bodean46
Normal. I run mine 1/2 quart low so i don't get the dreaded dripping from a/c. Keep an eye on it should be fine.
geezer glide 56's Avatar
geezer glide 56
I wouldn't worry about 1/2 a quart...I am not saying that it is normal...Just keep an eye on it...Did you check the oil before you left on your trip? did you check it with a cold engine or warm engine?...It makes a difference...Just keep an eye on it.
Old Sep 20, 2011 | 07:00 AM
jlacasci's Avatar
jlacasci
Are you saying you checked it before you left and after 1700 miles you are 1/2 a quart lower? If so, then that is a different issue. Could be a number of things. In my case, 2005 Ultra with 40,000 miles on it I needed a valve job. The other indication I had was she began to ping under load due to build up. She runs fantastic now.
Joe
Old Sep 20, 2011 | 11:01 AM
beaver07's Avatar
beaver07
Stage III
I serviced my bike before the trip and the level was full. I did check the level with the engine warm and on the stand. I bought the bike with 7300 miles and now have 10000 miles. I thouhgt that was low miles for oil loss. Any thoughts are appreciated. Thanks
Old Sep 20, 2011 | 11:32 AM
wheel752's Avatar
wheel752
1 qt. every 3400 miles... you can live with that..
Old Sep 20, 2011 | 01:57 PM
98Ultra's Avatar
98Ultra
Mine have always made a half quart dissapear in the first feww hundred miles and never drop below that.
That is, until my last trip, my 09 needed a quart to be half quart low. Gonna keep a close check after I do the service this week.
Old Sep 20, 2011 | 01:59 PM
Arizona's Avatar
Arizona
Ya that's whats still considered within "normal" oil usage. You may have leaky valve guides... The '05 models in particular were well known for that and my '05 EGC used a quart every 3k easily.
You'll just have to keep an eye on the oil level. You'll figure out your exact usage as time goes on, but you've just got one of those motors that uses oil.
Old Sep 20, 2011 | 08:39 PM
lowrider56's Avatar
lowrider56
My bike runs at a tad above the "add a quart" mark. Change the oil, fill it up, ride 500 miles and it's right back at a tad above the "add a quart" mark. Never runs hotter than it should (according to the gauge), good oil pressure (according to the gauge) and I've never had a problem with it in the 30,000 miles I have put on it. Did a 95 kit with new S&S geared cams about 15,000 miles ago. I could get on it tonight, ride 100 miles, check the oil and it will be where it always is. I guess that's just where the motor wants it to be. My mechanic says everything is fine. I used to worry about it but I don't anymore. Now I worry about the Inquisition coming to get me.
