Pop quiz; electrical problem
Old Sep 21, 2011 | 02:38 PM
Yukon42's Avatar
Yukon42
Default Pop quiz; electrical problem
Okay all you electrical guru's out there.....take a gander at the photo and tell me what caused these head light plugs in my 08 RG to melt like that. The worst part is in the ground connector. No, it ain't a short either.....
Old Sep 21, 2011 | 02:41 PM
slothy's Avatar
slothy
what bulbs are you running? possible shitty ground on the other end?
Old Sep 21, 2011 | 02:42 PM
Yukon42's Avatar
Yukon42
I should add that none of the actual wiring was damaged.
Old Sep 21, 2011 | 02:45 PM
Yukon42's Avatar
Yukon42
Stock bulbs.......you're close regarding the ground, but not quite correct. Anyone else?
Old Sep 21, 2011 | 02:46 PM
slothy's Avatar
slothy
damn so no star on the board for me lol...
only time ive seen plugs like that is when there is a poor ground. Cant wait to hear the answer
ImNoPrince's Avatar
ImNoPrince
Poor contacts cause this , blade connectors are not the best but the easiest to use . You can see the ones damaged are Opened up so they must have got real hot. A small amount of Dielectric grease will help this . There is a slight chance the Bulbs being over rated as well but normally it's just a not so tight connection at the blade.
Old Sep 21, 2011 | 02:47 PM
JRBass's Avatar
JRBass
Loose ground. Causing a heat build up?
Old Sep 21, 2011 | 02:54 PM
Yukon42's Avatar
Yukon42
DING, DING, DING, DING.....WE HAVE A WINNA!!!!! The cheap thin tinny spade connecters used in the stock plugs loosen pretty easily, which, as ImNoPrince points out, causes a high heat to build up around the connection. A trip to auto zone to buy some heavy duty, well built plugs with heavy spade connectors will be replacing these melted stockers. I shouldn't be having this problem again.
Thanks for playin!!!
Old Sep 21, 2011 | 03:22 PM
t. sawyer's Avatar
t. sawyer
I bought a bulb last week thinking it was out. No, same problem as yours. Ordered new one from HD. I went staight to the bulb with the wires and connectors. Taped off real good , and back riding till the connector comes in. Had a feeling that being loose might have had something to do with it. Dealer said he had seen that before. I have all kinds of those little connectors and none that size, typical huh?
Kroozeabout.
TSD
Jun 5, 2012 08:11 PM
The Nev
May 8, 2012 09:04 AM
PKellyMc
Sep 10, 2009 08:06 AM
marinepilot81
May 29, 2009 01:02 AM
wideopen
May 18, 2006 09:58 PM
