Blowing Running Light Fuse!!!?
Old Jun 5, 2012 | 04:49 PM
TSD's Avatar
TSD
Default Blowing Running Light Fuse!!!?
My 2000 UC has started blowing the fuse for the headlamps and rear running lamps. Anywhere I should check other than the obvious checking for bare or cut wires? Thanks for your input.
Old Jun 5, 2012 | 05:09 PM
mkguitar's Avatar
mkguitar
inside the rear fender, esp if the bike is lowered,
the tire can chew up the wiring
mike
Old Jun 5, 2012 | 05:38 PM
FDHOG's Avatar
FDHOG
Check behind the headlight. I had a similar problem with my RKC. Running lights and tail light. Wire behind headlamp frayed on the steering head from turning side to side.
Old Jun 5, 2012 | 08:11 PM
littled62's Avatar
littled62
had the same thing but it was my instrament fuse that kept blowing turned out it was one of the plug inns on the wiring harness had sorrosion on it cleaned it with contact cleaner and problem solved for some reason Haley fond it was ok to put rubber seals on some of the plugs but not others
Henway
Jun 19, 2017 07:29 AM
pretz
Sep 24, 2015 10:08 AM
StlJimmy
Feb 21, 2015 10:10 PM
Chopperbob
Feb 28, 2013 07:40 PM
86_Electra_Glide_Gal
Jul 8, 2006 06:41 PM
