bike still not running right
Old Sep 21, 2011 | 05:10 PM
VINNIE JAMES's Avatar
VINNIE JAMES
Default bike still not running right
i replaced the plugs and map sensor. still runs like crap. when i crack open the throttle the bike feels like its out of fuel...if im easy on the throttle it may run right??? it stalls sometimes...when takeing off in 1st gear, i have to rev the bike up and ride the clutch so it does not fall on its face.
any ideas??? thanks, vinnie
Old Sep 21, 2011 | 05:11 PM
BadBagger08's Avatar
BadBagger08
Dirty fuel filter?
Old Sep 21, 2011 | 05:14 PM
soft 02's Avatar
soft 02
Bad fuel?
Old Sep 21, 2011 | 05:16 PM
fabrik8r's Avatar
fabrik8r
Maybe TPS
Old Sep 21, 2011 | 05:33 PM
soft 02's Avatar
soft 02
Bad TPS should make a high idle and you can unplug it and it will still run but maby 03's are different.
Old Sep 21, 2011 | 11:51 PM
VINNIE JAMES
Fuel is good. Will try to disconnect the tps tomorrow. Thanks, Vinnie
Old Sep 22, 2011 | 05:04 AM
geezer glide 56's Avatar
geezer glide 56
Have you checked your fuel lines inside the fuel tank?
Old Sep 22, 2011 | 03:58 PM
VINNIE JAMES
how do u check the fuel line in side of the tank?
Old Sep 22, 2011 | 05:01 PM
soft 02's Avatar
soft 02
turn the key on and look in the tank for splashing (dont use a lighter). It will make a louder than usual fuel pump buzz also. FI bikes have issues with the clear plastic lines in the tank rubbing a hole in them.
Old Sep 24, 2011 | 01:20 PM
VINNIE JAMES
Disconnect the tps. And the bike is running better but not a 100%. Plug the tps back in and the bike would not run.
