Need Help- Electrical Problem
Old Sep 22, 2011 | 12:58 PM
sailnjay's Avatar
sailnjay
Default Need Help- Electrical Problem
My 2002 Road King (FLHPI) is blowing fuses for the brake lights and speedo. Can anyone give me any ideas on where to start looking for what might causing the problems.
I'm at work so I don't have any manuals with me and limited tools. I have a run-brake-turn module installed. I thought I would disconnect to rule that out.
Any and all help is appreciated.
Old Sep 22, 2011 | 01:17 PM
twincam47's Avatar
twincam47
probably your turn signals also.
check under the left side of your fuel tank....wires exit out the bottom of the tank for the fuel guage....sometimes this wire rubs on the front rocker box cover and chafs the wire and wammo.....That circuit for all that you describe is all in one....I had one that wouldnt do it at idle but when the speed or rpm was up it vibrated a different way, it would rub and pop the fuse every time....took me hours to find it.
Good luck and I hope this helps!
Old Sep 22, 2011 | 01:22 PM
mkguitar's Avatar
mkguitar
if you can. look at the fuse.
if it looks like the internal fuse wire just melted and sagged- that indicates a circuit overload.
if the fuse material is splattered and you see soot inside, that indicates a short circuit such as described above
mike
Old Sep 22, 2011 | 01:35 PM
sailnjay's Avatar
sailnjay
Thanks just checked that. Wire to the fuel gauge looks good and the fuel gauge is working.
Old Sep 22, 2011 | 04:06 PM
lasvegasrick's Avatar
lasvegasrick
unplug the rear lights at the run turn mod....wire may have rub through from rear tire
cchawg
Mar 22, 2020 07:42 PM
Dutch101st
General Topics/Tech Tips
Apr 1, 2015 09:52 AM
ndnbennyb
May 9, 2013 12:19 PM
Brieeen
Jul 5, 2009 08:01 AM
Balsam41
Sep 22, 2008 03:51 AM
