fast idle
Old Sep 22, 2011 | 08:41 PM
crackercap's Avatar
crackercap
Default fast idle
I started my 2011 Limited today and the idle would not go below 1400 rpm unless i rolled the throttle back as far as I could then it would idle at 1000 as is normal but once I released the throttle it would go back to the 1400 rpm. I called my dealer's service rep and he said to reset the throttle by turning the ignition from off to on several times and it would reset to factory specs. He said that evidently I rolled forward with the front brake on when I was turning the ignition off. I tried this but to no avail. Has anyone else had this sort of problem? I will take it to dealer tomorrow for them to "reset" it.
Old Sep 22, 2011 | 08:43 PM
Vitric's Avatar
Vitric
I remember there being a thread on here before about this, it's gonna take me a bit to find it though.
Old Sep 22, 2011 | 08:44 PM
soft 02's Avatar
soft 02
Sounds like a cable issue.
Old Sep 22, 2011 | 09:54 PM
08egstd's Avatar
08egstd
i had that problem if you shut your bike down before the rpm's drop the ecm will keep the idle where it was when you turned it off. turn the ignition on and off 10 times it will reset the idle and keep the switch on run. good luck it worked for me more then once
Old Sep 22, 2011 | 10:07 PM
1931jamesw's Avatar
1931jamesw
If you arent already doing it, get in the habit of turning off your bike with the ignition switch instead of the run/kill switch on the bars.
Old Sep 22, 2011 | 11:33 PM
user 8373900's Avatar
user 8373900
>>I started my 2011<<
No cables....
Mark
Old Sep 23, 2011 | 12:04 AM
dirtracin23's Avatar
dirtracin23
Uhhh................ 2011................ TBW. No cable
Old Sep 23, 2011 | 06:40 AM
sgt1577's Avatar
sgt1577
This does fix it, but you only need to do it 4 times. I've learned to wait till the idle slows down before switching it off
Old Sep 23, 2011 | 07:25 AM
coolerman69's Avatar
coolerman69
Your right! It is a cable issue! The problem is that it doesnt have um!
Old Sep 23, 2011 | 07:27 AM
locodude's Avatar
locodude
my 09 ultra idles really high (1200) at start up but goes to around 900 once it gets warm, takes about a half mile for it to calm down.
