can we wake up this 103
Old Oct 10, 2011 | 06:49 AM
  #41
mortbike's Avatar
mortbike
Originally Posted by 103RKC
Just came off the fm site looking at the 107 kit they have and the dyno #s with the tw555 cam and stock heads looks real good the only thing is the cylinder strong enough to take that much power and heat ??? can you safely take that much out of a stock cylinder ??? the combo is close the jack pot head pipe and the v&h power duels are somewhat the same I think they use a heavy breather I could do the work in a day and then get it tuned . It could be that it just needs a good tune and I am get to far ahead of myself. Has anyone had good luck with the se 254e cam set??? Or do you think this could be most of the problem
I have a 2011 SG 103 with SE 254e cams, Supertrapp Supermeg 2-1 full exhaust running 24 discs, HD SE Heavy Breather AC and tuned with SERPST tuner on the dyno by my dealer. Very happy with it, getting 102 ft lbs of torque and 88 hp with plenty of down low pull and pulls well up in to high rpms too. 2-1 pipes really help with low end torque and the supertrapp allows you to tune the torque curve by number of discs chosen. I like all around power through the rev range. I suppose I would have chosed 255 cams if I wanted to focus more on low rpm torque- Mort
jimfount00
Dec 22, 2014 09:23 PM
Rail
Exhaust System Topics
13
Sep 20, 2011 08:39 AM
Trek
15
Jan 27, 2011 11:58 PM
voodoodrug
Aug 18, 2010 10:07 AM
FLSTF
20
Oct 12, 2009 11:22 AM
