What they DON'T tell you II
Especially after any modifications. FLHS has been known to eat faring mounts. Mine had to be changed and the dealer wouldn't warranty it because I modified my engine. THEY did the modifying .
I don't know about anyone else, but I've done a lot of investigation regarding harley's excessive vibration problems. Many people like to say , that's just harley. Well not so. It doesn't vibrate when you purchase it. Or at least not mine. And many others that people have bought. Yet when the factory pipes come off and modifications begin, so does the vibration. Then its trips back to the dealer with no real results. If you do a search on google regarding Harley FLHX or Harley Davidson in general you will find many many post on excessive vibrations.
I first noticed mine when Harley modified my engine. 103 build. 585 cams . 10:0.1 compression. From that point it was a long laundry list of attempts to find the right build, plus eliminate vibrations . Both are pretty much impossible in my book .
I even went so far as to research into motor mounts . I went so far as to completely remove my stabilizers and loosen my motor mounts . then out it on a jack stand so it would set perfectly level. I then cranked the engine and let it idle. then i sat across the frame and gave it some throttle just to see what it would feel like. Still vibrations. All three motor mounts are brand new.
Allowing the engine to settle didn't help any. Vibration still there. Strong buzzing felt in the floor boards and back rest to the point after a hours ride your back and feet feel swollen and buzzing or tingling .
S&S 106 build . Bob woods 7G cams. 56 mm throttle body with injectors . 10:0.1 compression .Darkhorse reworked the crank TWICE !
This vibration has destroyed the enjoyment . Im thinking on going back to stock or a 110 stock. I have plenty of TQ & HP but the vibration is just to much to deal with on a comfortable level. Swollen feet hurt after a while.
Any Suggestions ?
The dealer modified your engine at your instruction. It was up to you to establish if that modification was appropriate for your needs. As your link shows there is plenty of public information about vibration, you should have researched your modifications before you had them done.
23 years/ 80000 miles
16 years/ 80000 miles
and the 09 has about 12000 miles.
( the '53 only has 25000 miles, it sat in a barn for 25 years)
As you pointed out in past posts, building up one part of the machine discovers the next weakest link.
As riders have demanded "comfort" the iso rear hub, motor mount changes etc have been brought into play- a built motor just chews up the rubber bushings.
...and building up the motor removes warranty support.
My stock 96" runs just great, it does everything that i could ever ask from a Harley touring bike
I've said before that it'll cost the equivalent of 2 kawasakis to make your bike go near as fast as one, and even then it won't last.
mike
mike
