View Poll Results: Would you or wouldn't you when it comes to dynoing your ride?
Dyno my ride as it is the best thing since sliced bread for quality tune.
42
70.00%
Auto-Tuner as good as a dyno w/out the wear w/Tweeking.
15
25.00%
Would never use a dyno to make a custom map.
1.67%
Would never try to make a custom map with an Autotuner.
3.33%
Voters: 60. You may not vote on this poll
Dyno or Not
Old Oct 12, 2011 | 12:13 PM
  #31
lionsm13's Avatar
lionsm13
Originally Posted by harleytuner
You're decel pop should be very easy to get rid of, just add fuel to your idle columns above 1500 RPM's and it should take care of it.
That's what I did, or at least in the Zero column and then subtracted it and still could never get it nailed down, and by the time that I got done taking everyone's suggestions,(read my last post) and adjusting (going plus-es and minus-es) the bike was so far out of tune it(and me too) couldn't take it anymore, and this was dealing with all of the experts(read my earlier post).
Had it been just that easy I would have thought tha Dyno-jet or Fuel Moto could have gotten it right... I would have thought from at least one of the 15 conversations that I had with them, wouldn't you?
Old Oct 12, 2011 | 12:20 PM
  #32
harleytuner's Avatar
harleytuner
Hrmm, that's odd. Usually when adding fuel to the zero colum takes care of it, or most of it. and it shouldn't effect your tune, since it's only adjusting the MAP on deceleration when you completely leave off the throttle. Are you sure you have your TP set correctly in the PC? One other thing would be to check for exhaust leaks, or cracks. That will cause decel pop as well.
Old Oct 12, 2011 | 01:47 PM
  #33
lionsm13's Avatar
lionsm13
Yes, was there too,(read number 29 post) after the cam change and went and bought new Muffler clamps for the slip-ons and rechecked the header bolts which did nothing..
TP and the works was set up with Roy Hartman of Dyno-jet in Las Vegas
Rabbs00
Apr 30, 2011 10:03 AM
cmcsns
Jul 16, 2010 10:29 PM
Adacas
Mar 12, 2009 10:18 AM
arkeglide
Aug 3, 2008 05:11 PM
parakiller
Mar 2, 2007 10:18 PM
