What's that noise ?
Old Oct 19, 2011 | 09:42 PM
kingkingking's Avatar
kingkingking
Originally Posted by speakerfritz
it's the exhaust pipes...they are not loud enough if you can hear noises in your primary
What he said.
Old Oct 20, 2011 | 08:53 AM
RoadHog659's Avatar
RoadHog659
Originally Posted by Hayhoss
OK, this is what they found. A lose primary chain. The auto adjuster hadn't yet jumped to the next notch ! They checked spring tension, alignment, ect. Went ahead and pushed into the next notch. They said that this is "the nature of the beast". But said if we have the same issue again, for as long as I did prior, they will replace the tensioner assembly. It sounds much better now, no $ charge. Craig
Thanks for the follow-up report. I have been wondering if I have a loose primary chain because I have been hearing a distinct primary rattle in the higher RPM ranges when shifting through the gears. Maybe my tensioner needs a push to the next notch. So far, nobody else hears it, or they hear it and call it "normal Harley noises". Thanks again for the post.
tkunk
11
Sep 1, 2013 08:01 PM
99octane
Dec 21, 2012 11:42 PM
shore
Oct 22, 2012 11:01 AM
GPHDXLC
Aug 23, 2012 12:58 PM
28gauge
Jul 19, 2009 03:13 PM
