cam suggestions
Old Oct 10, 2011 | 10:33 AM
tigerguy's Avatar
tigerguy
Stage I
Default cam suggestions
Hello all i am newly registered, and have been here and read post before. Now i have a question, i have a stock 06 streetglide TC88, and i am planning on installing this winter some parts i have been collecting SE heavy breather, SE super Pro Tuner, 2 into 1 thunderheader. the question is what cams should i use in combo with these items and stock 88 ci. was thinking the SE 203. im looking for the best streetable power ranges.
thanks in advance,
TG
Old Oct 10, 2011 | 10:59 AM
Mike's Avatar
Mike
203 would work pretty well in your bike. It will work better with a little more compression and the bump to 95".
Also consider the Andrews 21.
Old Oct 10, 2011 | 11:06 AM
XARAN's Avatar
XARAN
thanks in advance,
TG
The SE 203 is a good, mild cam but still EPA Complient so for me you are still leaving a lot of performance behind using this cam.
I like the SE 204 , very strong mid range power, good throughout the RPM range with no flat spots. Does not need more compression to perform..
I had these in my 05 fatboy and 2 of my friends with a RK TC88 and a RG TC 95 are using then with great results
Old Oct 10, 2011 | 11:09 AM
103 sedona orange's Avatar
103 sedona orange
You can find some great info if you do a "Search" on this site
Old Oct 10, 2011 | 11:18 AM
soft 02's Avatar
soft 02
https://www.hdforums.com/forum/touri...e-testing.html heres some good reading for you. Welcome to the forum!
Old Oct 10, 2011 | 12:05 PM
98fat's Avatar
98fat
I have the exact same bike (ok maybe a different color) and cams are my winter project as well. I am going with the Andrews 21 cam, (maybe a street port on the heads) and a two into one exhaust system (the current winner is the Vance Pro Pipe). good luck on what ever you decide.
Old Oct 11, 2011 | 02:06 AM
emwolb's Avatar
emwolb
welcome to the forum. i'm in agreement with XARAN with the choice of the 204 cams. wow, your first post, there's a lot of great information in here, enjoy.
Old Oct 11, 2011 | 09:50 AM
Harleypingman's Avatar
Harleypingman
Lots of folks, myself included, are very happy with the Head-Quarters HQ-0034. It's similar to the Andrews 26, S&S 510 and others. I haven't thought about a 95" kit since the HQ's were installed 4 years ago.
You don't mention what you're doing with the cam chain tensioners. A good upgrade is the SE hydraulic cam plate and high volume oil pump; ~$400 or so.
Good luck with your project.
Carl
Old Oct 11, 2011 | 09:54 AM
djl's Avatar
djl
SE204 or Andrews 26.
Old Oct 11, 2011 | 10:08 AM
RHillbilly's Avatar
RHillbilly
Look at the woods cams pricey but worth it
Ninersfan45320
Sep 19, 2017 10:51 AM
Wghussey
2014-2024 Touring Models
30
May 22, 2015 09:01 PM
smith1792
Apr 20, 2013 03:55 PM
Buckinfitch
Feb 5, 2012 10:43 PM
hougz79
Sep 6, 2010 10:20 PM
