Need some Help !!!
Old Oct 14, 2011 | 08:35 PM
GEORGEW's Avatar
GEORGEW
Default Need some Help !!!
I have a friend that has a 09 Street Glide with these add ons..
1.Big sucker A/C
2.PC-V
3.V&H Slipons
When you stop at traffic Lights ,,,it pops & Smokes through the A/C then the Motor Dies,, The Motor will start back and all is well until you find another traffic light..
It don't do this every time but will about five or six times everytime we go for a all day ride.
PLEASE TELL ME WHAT'S GOING ON WITH THIS STREET GLIDE,,,, Thanks
Old Oct 14, 2011 | 08:51 PM
drukanfu's Avatar
drukanfu
Are you the original owner or was the last owner Orville Rickenbocker ?
Old Oct 14, 2011 | 08:57 PM
mkguitar's Avatar
mkguitar
I'd disconnect, then reconnect the pc-v.
any change
next disconnect the pc-v, any change?
are the o2 sensors hooked up or bypassed?
if it is still doing it, then look for trouble codes
does it do it only when hot/cold or both
backfiring ( or "sneezing") thru the intake usually indicates a lean condition, intake leak, timing too advanced or, unlikely valve train problems, cam timing/ bent valve/ burned valve seat...but these would be apparent at higher speeds
mike
Old Oct 14, 2011 | 09:34 PM
z71_fourwheelin's Avatar
z71_fourwheelin
Make sure the correct map is programmed into the PCV.
Old Oct 14, 2011 | 10:45 PM
steelerdude1's Avatar
steelerdude1
My experience with back fires out of the intake is only or carbed bikes. But when I had this happen it was due to a lean condition. I fixed it by tweaking the Air Fuel mixture. My guess is your friends street glide does not have the correct map, and need to be richend up. Check his spark plugs and see if they are white in color, if so, that's the problem.
Old Oct 15, 2011 | 06:03 AM
GEORGEW's Avatar
GEORGEW
any change
mike
It
It only does this when Hot..
Old Oct 15, 2011 | 06:10 AM
Iceman24's Avatar
Iceman24
Who did the work on your friends bike (self or shop). If everything's installed correctly w/no leaks then the tuner's probably your culprit. Take mkguitar's advice & check it out...needs some adjusting, or has failed.
slvrscoobie
May 13, 2016 02:34 PM
homerandpooh
Exhaust System Topics
Jul 26, 2012 06:26 PM
2014streetglide
Fuel Moto / Jackpot Mufflers
Jun 8, 2011 07:40 PM
street_glider
May 16, 2010 10:50 PM
maddghost
Jun 15, 2009 08:23 AM
