Shifter Linkage Question
Old Oct 17, 2011 | 08:52 AM
nivensid's Avatar
nivensid
Default Shifter Linkage Question
When I shift the gears going at a normal speed I feel no vibration from the shifter linkage under the heel of my foot. If I get on her a little the vibration happens and increases with the speed until I get through the gears. I have no problem getting her in gear but the vibration worries me.
I am new to HD after riding metrics for 30 years and understand Harleys like to vibrate, that I like ,but is this normal?
Old Oct 17, 2011 | 08:55 AM
leohd's Avatar
leohd
its a harley and normal
Old Oct 17, 2011 | 08:58 AM
frenchbiker's Avatar
frenchbiker
Check your ball joints at the end of the linkage. They're prone to break. Carry a few plastic ties in case it happens when you're on the road.
I replaced mine by heim joints before they broke and I have no vibration whatsoever.
Old Oct 18, 2011 | 05:04 AM
luc.who's Avatar
luc.who
another thing to check is that the screw to tighten the shifter gets road grime in it an when you try to tighten it, it does not get tight. I took mine off cleaned it, dab of never seize and it snugged right up.
Old Oct 18, 2011 | 08:19 AM
imrotton2's Avatar
imrotton2
you keep your heel on the shifter all the time?????
Old Oct 18, 2011 | 08:26 AM
Geoff's Avatar
Geoff
Some vibration is normal. I swapped my stock linkage for the type with heim joints. It provides a firmer feel at the lever, and it looks much better than the stock part.
Old Oct 18, 2011 | 10:25 AM
nivensid's Avatar
nivensid
No, just when going to shift. Thanks for the all the info everyone.
cwsharp
Aug 22, 2022 11:54 PM
INJEKTER
Sep 12, 2015 06:33 PM
AmericanNightmare73
Ironhead
Jun 13, 2012 08:13 PM
sparky_mo
Apr 10, 2007 05:36 PM
Stkman
Aug 26, 2006 06:21 AM
