I'm curious which are louder the Jackpot 4" or the Pro Tour mufflers. I've decided on the Jackpot Stainless Steel 2/1/2 head pipes and now wondering about performance vs volume of the two mufflers. I don't want too loud.
Maybe this will help you decide (straight from Fuel Moto):
Stock mufflers, 78.4 dB @ idle, 90.9 dB @ cruise Jackpot Dyno Tuned, 83.6 dB @ idle, 93.9 dB @ cruise Jackpot Pro Touring, 89.2 dB @ idle, 97.2 dB @ cruise
The tests were performed using a 2009 (catless) Touring model with stock headpipes and Stage 1 air cleaner.
Adding Fuel Moto's S/S 2/1/2 headers will bump those numbers up a tad.
I doubt you will see a marked improvement with a 'muffers only' upgrade.
To maximize the performance return on your investment, you'd have to spend a bit more and do the Stage I upgrade. For an additional $225 (approximately), you can add a Big Sucker air cleaner and Nightrider fuel management and gain 7-12 HP in the process. Now, THAT'S bang for your buck!
I have fuelmoto's high flow air intake (combination of a screamin eagle breather and KN air filter) and their EFI tuner (USBIII) already installed.
