gauges acting funny
Old Oct 30, 2011 | 06:47 PM
leadman's Avatar
leadman
Question gauges acting funny
Just washed bike.Now the odometer says diag when you turn switch on.
The speedo & tach peg out and back & all indicator lights light up for a
split second.Think I got something wet? Never had her do this before.
dawg's Avatar
dawg
Yes. Coincidentally, when you pull the codes off the bike through the speedo you have to hold in the odo reset button as you turn on the ignition and the gauges will do the same exact thing when you do this. I'm betting your odo reset button is wet or on its way out because it is acting like it is being held in when you are turning the bike on
Old Oct 30, 2011 | 07:04 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Be careful squirting water on your bikes parts from the tops of the fenders up. Water is NOT your bikes friend in the faring area. There are plenty of cleaning options that do not involve water at all that are much superior. Sure, if the wheels and fenders are a mess, go ahead with soap and water to get the grit off. However, rethink the need for water in the area above the fenders. There are too many instances shared on this forum just like yours that are most likely a direct result of spraying water in areas at pressures and angles that can cause instant or near-future damage, issues, and error codes.
Old Oct 30, 2011 | 07:05 PM
leadman's Avatar
leadman
Thanks.Maybe it will dry out before
work tomorrow afternoon.
Old Oct 31, 2011 | 02:02 PM
dansflhti's Avatar
dansflhti
The same thing happened to my 09 Classic one time when i washed it back in the spring.It lasted for half a dozen starts and all has be good since,and there has been serveral washings since then.
Old Nov 1, 2011 | 09:03 AM
Northside's Avatar
Northside
If it hasn't gotten back to normal after drying out check your battery connections. If they are even a little loose this can occur.
Deucedog
Apr 29, 2018 04:55 PM
177hdking
Mar 25, 2012 09:38 AM
cws176
Jun 1, 2007 01:33 PM
jonhoffers
Aug 9, 2006 05:50 PM
RIEDEL
General Topics/Tech Tips
Jun 6, 2005 01:30 PM
