Quick Detach Mounting kit and the antenna mount question
Old Oct 30, 2011 | 07:07 PM
BALLS172's Avatar
BALLS172
Default Quick Detach Mounting kit and the antenna mount question
Did a search but nothing answered my question.
Got an 08 Electra Glide Classic used and the tour pack was removed from bike when I got it. It came with the rigid mount so I bought the neccesary kits to make it Q-D.
My question is on the right side of the bike the antennna is relocated in two holes on the strut behind the bag. The top of these two holes is needed for the rear mounting point (botom of the hoop)
Well the antenna does not clear the mount what have you guys done to make this work, is there another kit for the antenna I need. By the way the antenna will not be going back on the tour pack, I want the T-P to be a true quick detach.
Thanks,
Old Oct 30, 2011 | 07:15 PM
dawg's Avatar
dawg
Did you get 76326-00A antenna relocation kit? Sounds like you may have accidentally gotten 76208-07 antenna relocation kit
Old Oct 30, 2011 | 07:18 PM
mtclassic's Avatar
mtclassic
The other option is to put an antenna inside the fairing.
Old Oct 30, 2011 | 07:46 PM
BALLS172's Avatar
BALLS172
The 76208-07 looks exactly like what is on the bike, no good with the Q-D mounts. Looks like I need to run to the dealer tomorrow and figure out which mount will work...thanks for the help.
Old Oct 30, 2011 | 10:56 PM
Neil's Avatar
Neil
I used a similar setup for my Ultra. I just used a spacer to push the mounting bracket out some to clear the rails. Do a search under mu info. There should b a thread where I posted pics of what i did. If you want to leave the antenna on all the time you would probably need the lower mount.
Neil
RDMC
Old Oct 31, 2011 | 08:26 PM
BALLS172's Avatar
BALLS172
Update~ went to my local fastener store and bought some longer chrome bolts and chrome nuts to try as spacers. Did the job of bumping out the antenna mount perfect BUT the angle of the antenna is directly inline with the rear mount, I mean dead on ***** perfect inline. Looks like I will be going to buy that 76326-00A mount tomorrow. Thanks for the help all. Dawg you sure do know your Harley parts, been reading your advise all over this site, very impressive.
Old Oct 31, 2011 | 10:53 PM
Neil's Avatar
Neil
I just moved mine up using the bottom hole in the bracket and moved it so it is just about straight up and down. Just the slightest of angle back. Works great!
Neil
RDMC
Old Nov 1, 2011 | 09:09 AM
aviscomi's Avatar
aviscomi
+1 That's what I using on my 2010 SG w/detachable Tourpak
badazzpred
Aug 26, 2011 08:47 PM
Norm58
General Topics/Tech Tips
Jun 20, 2010 11:02 PM
papapuskit
Feb 1, 2008 11:28 PM
bigbean78
Nov 4, 2007 07:25 AM
kevdog
Jul 25, 2006 08:51 AM
