Primary drain plug help needed
Old Oct 31, 2011 | 10:42 PM
electradad's Avatar
electradad
Originally Posted by noserider
Dawg that would explain alot. How can I be sure or are you sure?
Thanks
Noserider, do your research on Dawgs post if you want. I've never met him, and I can tell you right now, if I was looking for info, he would be one of the first I would look to. He knows his stuff.
Old Oct 31, 2011 | 10:53 PM
noserider's Avatar
noserider
Sorry I was away from the computer. Right after i asked dawg if he "was sure" I noticed his 17k plus post. That's generally a pretty good sign who your dealing with. Dawg I'm new here. Clearly you know you stuff and I appreciate the quick reply. One more question if I may. There is some type of sensor in the way of my oil filter wrench. Will the special Harley filter wrench solve this?
Thanks
Old Oct 31, 2011 | 11:37 PM
electradad's Avatar
electradad
lol.. You will have that. Welcome to the forum btw. I dont know if you are a "hafta use HD parts" kinda guy or not. But I use K&N filters on mine. They have a nut on top of the case. Put a 3/4" socket on it, twist if off and you are done. They are within a few bucks of the HD filter.
Old Oct 31, 2011 | 11:49 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
My 04 has a npt tapered thread on the primary. Manual says ms sae plug with 0-ring. Some variation. However if it looks like this you are trying to use wrong o-ring. The o-ring shoud be tight and it goes up into taper in port. The washer face bottoms metal to metal so it stays tight. If it has no groove and looks slightly tapered you use teflon tape on it.
Old Oct 31, 2011 | 11:53 PM
2black1s's Avatar
2black1s
... How can I be sure...
Simple! Look at the plug.
Does it have a shoulder and groove for the o-ring to seat into? Then it gets the o-ring.
Or is the plug threaded it's entire length? In this case, no o-ring.
Old Nov 1, 2011 | 07:12 AM
dawg's Avatar
dawg
Thanks
Yes, there is a cut out in the wrench to get around the sensor. Read up on changing the oil filter without creating a mess before you pull it off as it can be a real mess if you don't take precautions such as rigging a soda bottle, carboard, form a funnel, etc.
Old Nov 1, 2011 | 08:02 AM
SBW Cycles's Avatar
SBW Cycles
Does anyone happen to know the size of the primary drain plug o-ring so we can purchase them elsewhere such a Lowes or Home Depot? I found the oil drian plug o-ring size but cannot find the primary for the 04 models.
Old Nov 1, 2011 | 08:12 AM
santajim's Avatar
santajim
Two things
Newbes should be taught from the day they join that if the DAWG speaks it is gospel.
on my '09 all three 'O' rings are the same size.
Old Nov 1, 2011 | 09:32 AM
cdestuck's Avatar
cdestuck
Not sure of what type of gasket is on the primary cover but if its at all like the late model ones, reuse the old one to save some money. I have reused them over and over with no leaking.
Old Nov 1, 2011 | 10:20 AM
TWIN CAM 96's Avatar
TWIN CAM 96
Originally Posted by dawg
99-03 uses the tapered plug, 04-06 use the plug with the 11324 o-ring and 07-present use the 11105 o-ring
Looks like he's doing his homework.
