Primary drain plug help needed
Old Oct 31, 2011 | 09:18 PM
noserider's Avatar
noserider
Default Primary drain plug help needed
Doing my first service on my new to me 2001 FLHT. I bought the gasket kit for the service. I'm a little confused on the primary drain plug o ring. When I snug the drain plug it just squeezes the o-ring right off the end and it falls on the ground before the drain plug gets tight. If I leave the o-ring out the plug tightens up fine. So how does that o ring stay in place??
Old Oct 31, 2011 | 09:19 PM
dawg's Avatar
dawg
01 primary plug should be the tapered one that doesn't use an o-ring
Old Oct 31, 2011 | 09:23 PM
BackRoader's Avatar
BackRoader
My 06 EG has no 0-ring on the primary plug, but my buddy's 05 Heritage does. Go figure.
Old Oct 31, 2011 | 09:26 PM
soos's Avatar
soos
'06 SM shows an O-ring.
Old Oct 31, 2011 | 09:34 PM
noserider's Avatar
noserider
Dawg that would explain alot. How can I be sure or are you sure?
Thanks
Old Oct 31, 2011 | 09:38 PM
Jim Dawson's Avatar
Jim Dawson
Thanks
Look in a parts catalog for your model bike and see if it shows an "O" ring. Your dealer should have one if you don't.
Old Oct 31, 2011 | 09:43 PM
soos's Avatar
soos
Check this link. It is a schematic of your model year primary cover. It shows your drain plug without an O-ring.
Old Oct 31, 2011 | 09:51 PM
dawg's Avatar
dawg
Thanks
Guess ya just gotta trust me.
Old Oct 31, 2011 | 09:55 PM
soos's Avatar
soos
For a minute there, I thought you nodded off...zzzzzzzzzzzzzzzzz
Old Oct 31, 2011 | 09:57 PM
dawg's Avatar
dawg
99-03 uses the tapered plug, 04-06 use the plug with the 11324 o-ring and 07-present use the 11105 o-ring
