should I change cams
Old Nov 5, 2011 | 03:07 PM
dbell66253's Avatar
dbell66253
Search through the threads, almost any cam is better than stock, has nothing to do with where the cam was made. Just depends on where you want your tq at.
Old Nov 5, 2011 | 03:17 PM
klaybus's Avatar
klaybus
The 255s are very affordable if your looking for good torque for a bagger. The Woods TW 555 make great power & numbers. Depends on what your looking for. Lots of reading available if you do a search......
Old Nov 5, 2011 | 03:25 PM
Mike's Avatar
Mike
Originally Posted by mrfikser
Ok, what is a good set of cams for my situation ( I don't carry a lot of weight, want good gas mileage and ride in both city and highway)...if I can boost hp/tq and keep the gas mileage good (if I stay out of the throttle) than why not...
Andrews 37 is a good bolt-in for the 103 motors. I'm currently running 204s, which work well in a bagger motor at 9.6 to 9.8 compression. Good hit right off idle, nice old-school idle, and good mileage as long as you've got a good tune. Problem with the 204s is you've pretty much have to have a dyno tune, or run one of the auto tune units. (I've currently got the PCV with autotune).
255s are the cam of choice for many bagger owners, they work exceptionally well in the heavy bikes, and the short duration helps keep fuel mileage up. Not a big hp cam, though.
There are so many cams to choose from that picking one can be somewhat daunting, but in reality, almost any cam will be an improvement over stock, and as long as you stay with the more conservative grinds, you almost can't go wrong. Woods 5, 555, 6, Andrews 48, 37, SE255, 254. 204, CycleRama 575 to name a few. Every one of these cams have been used in similar builds to yours, and have had good outcomes.
Don't fall into the trap of getting all wrapped up in other people's dyno charts, trying to chase the most hp, or worrying about exactly where the torque curve starts. Look for a conservative grind that other folks speak highly of, and you'll be good to go.
Old Nov 6, 2011 | 06:47 AM
mrfikser's Avatar
mrfikser
Don't fall into the trap of getting all wrapped up in other people's dyno charts, trying to chase the most hp, or worrying about exactly where the torque curve starts. Look for a conservative grind that other folks speak highly of, and you'll be good to go.[/quote]
Ahhh, this is the type of answer I was looking for...thanks
bullet 10
May 27, 2016 10:52 PM
Chicago Ken
Feb 9, 2013 08:59 AM
flattracker60
Jul 16, 2011 11:27 PM
mateo613
Mar 20, 2011 09:29 PM
evostroker
Exhaust System Topics
Dec 3, 2010 09:36 AM
