Ok i got a cpl questions for you internet experts .
how many of you have expermented changing to diffrent oil weights in shocks to tune them ?
I own a 2008FLHRC i wanted to lower the rear one inch but most lowering blocks will not work with the leather wrapped bags . so i bought a pair of 12" low touring shocks from ebay OEM part #54662-02A low.
i know my stock 2008 13" air shocks take max presure 35psi . I understand the 09 and newer shocks take 50psi max . so how do i determine if the shocks i bought are 09 newer or older ? does the part # tell ? also is the max presure diffrence due to the the airlines ect on the bike or the shocks ?
i am asuming theses shocks have the 5w stock oil i am debating wether to put them on this way or change out to 7w oil . i weigh 190lb.
the seller said the shocks were installed on a 2007 electra glide for a short time .. but didn't know if it was recently "newer shocks " or not .
Now if i change the oil i know the 13" shocks take 10.5 oz oil .do the 12" shocks take the same amount ?
how will alteering the amount of oil in each shock a few onces alter the ride?
i know my stock 2008 13" air shocks take max presure 35psi . I understand the 09 and newer shocks take 50psi max . so how do i determine if the shocks i bought are 09 newer or older ? does the part # tell ? also is the max presure diffrence due to the the airlines ect on the bike or the shocks ? i am asuming theses shocks have the 5w stock oil i am debating wether to put them on this way or change out to 7w oil . i weigh 190lb.
the sealer said the shocks were installed on a 2007 electra glide for a short time .. but didn't know if it was recently "newer shocks " or not .
now if i change the oil i know the 13" shocks take 10.5 oz oil .do the 12" shocks take the same amount ?
they would have a -09 at the end if they were 09 up shocks, use10w Amsoil Shock Therapy, don't remember the amount but look around, its here. 35# max for the shocks you got.
thanks . i am leaning towards changing out the 5w oil for 7w or 10w before i install them . i weighed them to see if they had equal amounts of oil in each shock .they came sealed with caps and looked neer new little signs or ware
With the pre-09 shocks, I would recommend starting with 10w Amsoil or equivilent. Be aware there are wide variances in viscosity characteristics among diferent brands of XXWt fluid. I had great success with the Amsoil as have many others. It is a very good interim mod for the rear suspension.
