Timken part # needed.
Old Nov 9, 2011 | 06:26 PM
Cotton Hill's Avatar
Cotton Hill
Thanks Harded; Being that my wife and inlaws are all from Canton, OH I want Timken Bearings. If nobody comes up with the part # I'll post it when I cross my OEM ones over.
Old Nov 9, 2011 | 06:48 PM
69cj's Avatar
69cj
Good Luck, If you come up with a timken cross over for the one inch bearings, please do post. Bearing houses here could not do it.
Old Nov 9, 2011 | 07:20 PM
machinehed's Avatar
machinehed
Default timken bearings.
Shouldnt be a problem , any bearing supplier should be able to cross your timken # to any other .?
Old Nov 9, 2011 | 07:23 PM
69cj's Avatar
69cj
You're wrong there. The two biggy suppliers here couldn't do it.
Old Nov 9, 2011 | 08:55 PM
vzts4q's Avatar
vzts4q
I believe the 08's use a sealed ball bearing so there will be no cross reference to a Timken! (tapered roller)
Old Nov 9, 2011 | 09:00 PM
lightweight bob's Avatar
lightweight bob
You're correct - sealed deep groove ball bearings FWIW.
Old Nov 9, 2011 | 10:05 PM
BrianG's Avatar
BrianG
Have you tried this?
http://www.timken.com/EN-US/Knowledg...artNumber.aspx
Old Nov 9, 2011 | 11:02 PM
X Iron Butt's Avatar
X Iron Butt
Timkin bought Torrington (see this thread Harderd) 8 years ago. Torrington is ball bearings.
According to Ronnies HD microfiche the 07 Ultras (and a bunch of others) started using the 25 mm bearing. From what I can put together this is a single row sealed ball bearing. Too many models to check them all and microfiches have been wrong before a few times.
Somewhere aroung 2000 they went from the tapered roller bearing that my 1979 shovel head has to a two row sealed ball bearing.
Personally I think the double row ball bearing would be the ****. The tapered roller was way over engineered and you had to pack it. I could be way off on that opinion because I haven't heard much about problems with them. That might be a good thing.
I believe most of these ball bearing changes were due to anti dumping laws but Harderd probably knows more about that.
I guess the only way to find out for sure is pull my wheel and the bearing and look at it.
BrianG your link is for tapered bearings. And I don't have the exact HD dimensions until I pull my wheel and bearing.
Good Night
Old Nov 12, 2011 | 06:09 PM
Cotton Hill
I had to settle for std. HD parts. Now that I have the OEM bearings out I'm going to send them to my sons Father inlaw. He works at Timken in Canton we'll see if there is a real Timken part # . If I do get one I'll post it on the board.
Old Nov 12, 2011 | 06:35 PM
lightweight bob
Default HD Wheel bearings
Just curious - how much did the stealer hit ya up for each bearing? X Iron Butt is
looking in the $6 - $8 dollar range for quality bearings. When he finds them I hope
he lets all of us know.
