Inner fairing gasket installation question
Old Nov 20, 2011 | 05:37 PM
kjkustoms's Avatar
kjkustoms
Question Inner fairing gasket installation question
I am in the process of re-installing my inner fairing, just had it painted. My question is , I was going to re- install the rubber gaskets that goes between the inner and outer fairing before I install it, When I removed the gaskets they came off pretty easy, It had some glue from factory which held up really well, what should I use to glue it back on without a big mess? If you order new rubber gaskets do they come with an adhesive already on them? Any help would be appreciated .
Old Nov 20, 2011 | 05:44 PM
redrubicon2004's Avatar
redrubicon2004
I left mine off. I cant recall many bikes with painted inner fairings that put them back on. Kinda brakes up the color.
Old Nov 20, 2011 | 05:46 PM
dawg's Avatar
dawg
Yes the new gaskets come with glue in them that adhere when you install. For the minor price of the gaskets, I'd buy new instead of messing with re-gluing.
Old Nov 20, 2011 | 06:18 PM
BBStacker's Avatar
BBStacker
What Dawg said, replaced mine when I had my inner done. As far as leaving them off....I'm thinking they are called gaskets for a reason. Keeps h2o outta the inside of the fairing or maybe just to prevent plastic rubbing on plastic. My guess is the latter.
Old Nov 20, 2011 | 07:03 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Always reinstall the gasket.
Old Nov 20, 2011 | 07:15 PM
thecort's Avatar
thecort
Definitely reinstall that gasket. If yours is still in good shape then reinstall it with 3M car emblem adhesive or clear silicone. DO NOT load it up. Use small dabs. Should be fine.
Old Nov 20, 2011 | 07:25 PM
themensh's Avatar
themensh
I never saw a gasket at the windshield.....so I don't know how "water-proof" the gaskets on the fairing will be.
chuck the mensh
Old Nov 20, 2011 | 07:43 PM
Wanna Ride's Avatar
Wanna Ride
The two gaskets aren't necessarily for keeping water, but more for protecting the two fairing halves from scratching the paint on each other. The gaskets are about four bucks each, and come with adhesive.
Old Nov 20, 2011 | 10:31 PM
leohd's Avatar
leohd
buy new glueing the ol ones is a mess and they will come out eventually.
Old Nov 20, 2011 | 10:34 PM
tincup64's Avatar
tincup64
i got a new gasket set with the fairing. glad i did. i had planned on rubber cement with a toothpick only to find it was already on the new gasket. buy a set - worth it.
tin
