1998 FLHP specs
Old Nov 23, 2011 | 06:22 PM
green53's Avatar
green53
Default 1998 FLHP specs
Hi, can anyone post specs for a 1998 FLHP, and pics can't seem to find specs anywhere. Thanks.
Old Nov 23, 2011 | 06:34 PM
T_Sebastian's Avatar
T_Sebastian
http://www.bikez.com/motorcycles/har..._king_1998.php
best I could do...
Old Nov 23, 2011 | 08:03 PM
Lakerat's Avatar
Lakerat
Probably the only thing you will find different in the specs compared to a standard model would be the charging system and possibly a factory oil cooler. Equipment is another matter.
Old Nov 23, 2011 | 08:21 PM
mkguitar's Avatar
mkguitar
Being at evo cop bike, it may have milled heads and a performance cam and performance ignition module
( some do, some don't depends on the ordering agency, my 88 CHP FXRP does)
It will also probably be lacking the evaporative canister
Mufflers will be similar to stock as is the air cleaner
high capacity charging system as noted above
It may have dunlop run flat tires, which are handy for flats, but are an ultra hard compound, not so good in the wet
mike
Old Nov 24, 2011 | 05:32 PM
green53's Avatar
green53
Thanks for the replies, so should this bike have a twin cam 88 with a CV carb?
Old Nov 24, 2011 | 05:38 PM
Stiggy's Avatar
Stiggy
98 was the Evolution ( 1340 cc / 80 ci.)
99 and up is the Twin Cam ( 1450 cc / 88 ci.)
cskarns
EVO
20
Apr 17, 2018 02:51 PM
Big Panda
EVO
30
Aug 18, 2017 07:26 AM
Go Shovelhead Go
Shovelhead
Jan 20, 2014 08:56 PM
lespaul60
Jul 18, 2011 03:13 PM
murf1
May 22, 2008 05:33 AM
