2012 FLHRC here, I'm at about 39.X in cold weather mixed riding (just got it in October), running V&H fishtail slip ons, SE A/C and FL-VIEDS, I'd expect to get a bit better in warm weather.
Moving to Fuelmoto coated X-pipe in the spring will be very curious how that affects mileage.
Warm air is harder to compress than cold air so you should get better mpg during cold weather
I'm sorry, but that's exactly wrong.
http://www.swri.org/10light/mile.htm "With this in mind, hot air is less dense than cold air; therefore, the engine breathes less hot air per revolution and requires less fuel."
And given that cold air is more dense than hot, it makes sense that more fuel is required to get the same AFR at a lower air temp, therefore.
About: http://www.swri.org/6swsa/work/facts.htm
"Southwest Research Institute (SwRI), headquartered in San Antonio, Texas, is one of the oldest and largest independent, nonprofit, applied research and development (R&D) organizations in the United States. Founded in 1947, SwRI provides contract research and development services to industrial and government clients in the United States and abroad. The Institute is governed by a board of directors, which is advised by approximately 100 trustees."
It depends on which one you want more than the other: better MPG, or more power.
At higher temp (hot air), the engine will have less power than at lower temp (cold air).
The study above is just for car which has a radiator and thermostat to keep the engine at a constant temperature, so it's different than the air-cooled engine.
I'm usually in the 40-41mpg range, but have had some tanks in the mid 30's, and a couple around 45. The bike gets it's best fuel economy under 60mph or so, but I exceed that on the freeways around here all the time.
