i'm also doing a 21 inch conversion on my 10 streetglide. looking to do the 13" rotor and a jaybrake 6 cylinder ultra brake. my drag book does not show the availability of a 13 inch performance machine rotor for this model nor does jaybrake show the j-six ultra caliper for a 13 inch rotor on a 2010. anyone shed some light on this or part numbers that will work? i would like to order through drag due to a discount i am recieving.
I know they make the wheel to fit a 2010 SG because that is the same wheel I ran on my 07 SG and besides the axel size changing (which should only affect the hub) they should be the same wheel. I only ran the stock rotor then so not sure about a 13" rotor. If one of the site sponsors don't chime in... Call Brian at Eastern Performance... That's who I bought all of my PM parts from and they know thier stuff!
bufftuff,
PM's rotors will fit your 2010 street glide without ABS with no problem at all. The fitment for is 11.8", and PM offers matching chrome 2 piece rotors for that Hooligan front wheel set you are interested in. Check out our tech articles on what you need to do to switch over to single side, and email me at david@wanaryd.com if you have any other questions or if you would like to move forward with that eBay listing, Ryd Safe!
Wanaryd, ordered my 6 piston 13" caliper last week, got souther wheel sending me a matching rotor, I see alot of 9/16 bore masters on eBay for soft tails and dynas, are these a direct fit for my 06 flht?
