Built the best engine cooling system...again
Old Jun 18, 2012 | 09:04 PM
  #591
iclick's Avatar
iclick
Originally Posted by b17467
I have the same thing happening and I don't live on a gravel road. I was thinking how long it's going to take before it gets punctured. I'm at 17,000 now and wondering what my oil cooler is going to look like at 34,000.
I have almost 55k and 5˝ years on my cooler and although it has some minor wear there it nothing of concern, but I do stay away from gravel roads like the plague.
Old Jun 18, 2012 | 09:17 PM
  #592
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
The Jagg 10 row is pretty simple to protect. I cut the screen just slightly wider than the finned section. flex it outwards a little and it kind of locks in place on the top and bottom of the fin section, used a piece of stainless wire in the 4 corners and twist wired it through the heat exchanger fins. the screen flexes outward and is kinda springy so stuf will bounce off it. Its a little dirty and banged up but you can see how I Hooked it up in the pics.
Attached Thumbnails Built the best engine cooling system...again-100_1400.jpg   Built the best engine cooling system...again-100_1401.jpg
Old Jun 19, 2012 | 06:27 AM
  #593
Rickr01's Avatar
Rickr01
Not much one can do when you live on over 6 miles of poorly maintained gravel road! At least I got the town to stop laying down calcium chloride every summer to keep the dust down. That crap permeated every nook and cranny on the bike and would almost immediately cause corrosion. Was washing the bike more than riding it.
Old Jun 19, 2012 | 08:40 AM
  #594
tryus's Avatar
tryus
Originally Posted by WARDSPARTSWERKS
You contacted me originally via the website so I put you on the public list, then let me know you were an HDF member so I shifted you over to the Forum list, My appologies.
Anyone else with specific contact instructions needs to let me know, the list goes by your forum name and thats how I normally contact folks, happy to send an email if you provide an address.
Hey Jason, you about ready for a business manager haha!
Old Jun 19, 2012 | 10:56 AM
  #595
viperr817's Avatar
viperr817
Payment sent.
Old Jun 19, 2012 | 11:07 AM
  #596
iclick's Avatar
iclick
I can make the harnesses a little longer, that’s too easy, but the problem is I already cut the sleeves for 50 sets last weekend. Too long is just as bad as too short sometimes, everybody in agreement +4" will be enough?
I may have missed something along the line, but I assume the intermediate connection (blade connectors) is there to allow those of us using external switches to connect easier, but if so why not make the first length of wire from the fans reach under the seat. As it is the blade connectors are exposed to the elements and if extended would be protected under the seat.
Old Jun 19, 2012 | 11:11 AM
  #597
iclick's Avatar
iclick
You could also attached the screen by running some wire-ties through the cooler connecting front and rear. IOW, run a wire-tie through the cooler with the stub end holding the screen in place. Then attach the stub end of another wire-tie to the rear and cut it. When I was experimenting with cooler fans I secured them this way. I would also probably attach a small washer on the front between the stub and screen.
Old Jun 19, 2012 | 06:31 PM
  #598
fabrik8r's Avatar
fabrik8r
So you don't have to remove the entire harness from the chassis conduit, under the tank, and unhook connections under the seat in order to remove the fans, for whatever reason; same reason the horn has disconnects. As far as the elements go, snoop around your entire chassis electrical system you'll find a bunch of connections that aren't protected from the elements. I used shrouded disconnects and you can apply dielectrical grease to make it virtually waterproof. Wiring is never going to fully accommodate all concievable configurations, but I do include an extra set of disconnects for those who want to get real creative with their wiring.
  #599
In2It's Avatar
In2It
Update I was one of the first to istall these fans and I can't say enough about the cooling effect.It's 104 here in EL Paso,Tx and was out in it and the bike oil temp never got over 190 and rear CHT 220.When I got home checked the HD digital dip stick just for yucks and it read 230 with bike off so I checked it against my indash gauge and read the same.I'm really happy with Jason turning me on to his cooler thermostat and F.C.S and all the other suggesting he made as far as getting my 08 Ultra to run cooler.I'm confident no matter how hot it gets out my set up will keep my bike running cool.Thanks again Jason
Old Jun 19, 2012 | 09:21 PM
  #600
TXSailor's Avatar
TXSailor
Hey In2It - What were you doing when the Oil peaked at 190 since it obviously went higher later in the trip.?
Are you also saying that the oil when from something like 190 to 230 (at rest) when you finally shut down the engine? Did you happen to get a CHT when the oil was 230?
I ask because 230 is about where my oil ends up once I come off the freeways in Houston and get to the House. I have a HD Oil Cooler with Jason's cooler T-Stat as well. The Front CHT is usually about 245 by then but cooling down via the fans.
As a rule of thumb, I try to run the fans at least a couple of minutes (taking the gear off, unpacking the bike, etc.) before I turn it off.
Thanks, D
