Throttle By Wire.. What a Shame...
Old Dec 15, 2011 | 10:14 AM
  #41
hoethree's Avatar
hoethree
Originally Posted by jeffreyjames
Hey All.. I have a '10 RKP.. Love it, great bike, great frame, etc.. But I just can't stand the Throttle by Wire.. I had a 1200 sportster carburated years back and the throttle response was like a fire cracker blast.. Now even with impressive engine numbers, the throttle response isn't what I had hoped.. Does anyone else notice this, and if so, is there a remedy? My indie said that the delay that is because the throttle sensor has to travel the message to the computer then to engine to produce response and is lagged.. ARgh..
Old Dec 15, 2011 | 10:41 AM
  #42
jeffreydsilver's Avatar
jeffreydsilver
Default Just My .02
Good point, but then why would vance and hines release a throttle pak specifically for tuned TBW bikes? Seems like it is a known issue.
09 Road King here. Throttle response was crisp factory stock and the same with slip on mufflers and a fuel pack after mod. I used the fuel pack to get rid of excessive decel popping. It never even occured to me that there was a throttle delay. With what I have learned about tuners I don't know that I would use a V&H throttle pack. If it's anything similar to the fuel pack I would think it would be very limited in its settings and what you could do with them!
Guess I'm lucky? Never had a throttle response issue.
Old Dec 15, 2011 | 10:47 AM
  #43
PistonPuller's Avatar
PistonPuller
Those of you who changed the progressivity with your race tuner, can you post a pic of the table? I am curious to compare mine.
Old Dec 15, 2011 | 11:46 AM
  #44
rocknrod's Avatar
rocknrod
What really upsets me about these new bikes is the new fangled hydraulic brakes. Boy did they go astray there.
Old Dec 15, 2011 | 12:47 PM
  #45
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
I have found firsthand that the response (or lack of) on the DBW bikes is just as much or much more related to the factory tuning itself rather than the DBW system itself. It is combination of lean mixture, excessive accelleration enrichment, and less than optimum ignition timing in the stock calibration all combined together. The ECM also uses various strategies as forms of torque management to help with driveline lash and off idle low RPM abruptness. When the fuel tables and igntion timing are properly tuned throttle response is generally very acceptable even with the base throttle table, however there are several products as noted earler such as Dynojet Power Vision, SE Pro Race Tuner, and TTS that allow you to adjust the throttle blade (Power Vision even gives you 2 tables to adjust this with). I have hundreds of logs of the throttle blade strategies on drive by wire bikes and have adjusted the throttle tables all over the place monitoring the results using the factory and aftermarket calibration (for reference most aftermarket calibrations actually use the same throttle blade base settings as stock) I do agree that the ability to adjust the throttle blade tables is very helpful when needed and in some application have made very measureable results, however if you have any of these products before making any big adjustments to the throttle tables I recommend doing some data recording and logging MAP, TPS, and Twist Grip position and this will really help understand the strategy. It is also important to unserdtand that because the throttle blade directly affects manifold pressure that changing the throttle blade settings can and will directly affect the other tables in the tune as the Delphi speed density system uses manifold pressure and intake air temp to determine air mass. Hope this info helps........
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Dec 15, 2011 | 12:57 PM
  #46
big ears's Avatar
big ears
Don't notice any lag on my 09.
Old Dec 15, 2011 | 01:09 PM
  #47
Copyless's Avatar
Copyless
Originally Posted by Shutterbug
Can a TTS be mapped with a canned configuration so you can use until you get to a tuner? Or does it have to be tuned once installed?
I believe you have a misunderstanding of the TTS, so I'm going to throw this out there just in case.
The TTS is a programmer, is does not get "installed" you connect it to the ECM and re-program the ECM, then you remove the TTS and put it away. It does not stay connected like some other modules.
Old Dec 15, 2011 | 01:25 PM
  #48
Deuce Bigelow's Avatar
Deuce Bigelow
Originally Posted by ktm_scott
Those messages are traveling at the speed of light, I don't think the distance is the issue. I have no response issues with Hester.
it does not move at the speed of light.. because we are not using fiberoptics.
but it is fast merely because the wire is already filled with electrons, so the action is near instantaneous..
think of a copper wire as a pipe completely filled with water, then forcing a drop of water in one end will result in a drop at the other end being pushed out very quickly.
Old Dec 15, 2011 | 02:19 PM
  #49
2black1s's Avatar
2black1s
Even though we're not using fiber optics, electricity is nonetheless said to travel at the speed of light. Now I'm not a physicist and can't explain every detail, but as a engineering rule-of-thumb this is true.
Old Dec 15, 2011 | 02:27 PM
  #50
hoethree's Avatar
hoethree
When I pull the plug from the wall outlet on my Christmas tree, ALL the lights go out at the same time....not the first one, then the second one, then the....etc.
