They worked out well for me, also. No more back pain. I ran the wiring inside the bars and really cleaned up the front of the bike. Finally, a bargain from the MOCO.
Neckball, did you install the HD RK High Handlebars (P/N 55954-00)? These are pre-drilled for the inside wiring?
That's the part number. These are not pre-drilled but they are dimpled at the controls. It was fairly easy to drill them at the dimples and then cut an oval opening in the center of the bars. Take your time, measure twice and cut once. De-burr everything carefully.
