Air Ride install Part 2
Old Sep 14, 2012 | 11:21 AM
  #111
Str33tgl1de's Avatar
Str33tgl1de
anyone run this setup with an air tank instead of having a compressor? i know you would need 2 valves but you wont have to worry about the compressor filling the shocks you would have the air on demand.
Going one step further if you use C02 you can fill and dump more than you would want to in one ride and not run out of air.
Old Sep 14, 2012 | 12:04 PM
  #112
Harley2534's Avatar
Harley2534
Needing to see if anyone might have a picture on how there switch is mounted. Starti
ng to put an air ride on a friends SG.
Old Sep 16, 2012 | 11:50 PM
  #113
twistedcherokee's Avatar
twistedcherokee
I started to put mine together, but didn't want to move any of the stock things (ECU, right side & CC module left side). So I put mine under the battery box. It was a little tricky but manageable. Name:  100_1364.jpg
Size:  12.2 KB Name:  100_1366.jpg
Size:  16.5 KB Name:  100_1367.jpg
Size:  15.8 KB Name:  100_1368.jpg
Size:  8.6 KB Name:  100_1369.jpg
Size:  14.5 KB Name:  100_1370.jpg
Size:  10.1 KB more to come
Old Sep 17, 2012 | 12:02 AM
  #114
twistedcherokee
Size:  16.2 KB Name:  100_1373.jpg
Size:  15.1 KB Name:  100_1374.jpg
It looks like it is as dry as under the covers & may be easier than moving stuff with a wiring harness to a different spot. I know one moved the ECU to under the battery, but my ECU looked too wide to fit well, but mine is a 1999 & the ECU might be bigger. I had to remove the battery box, I installed the compressor bracket loosely on the box, took the compressor & put it in the area that I was going to install it at & then put the box back in. The picture of the bracket on the box didn't work so I had to move it towards the rear of the box (starter was in the way). I might put a piece of plastic or aluminum to shield it from the belt debris, will check it in a couple of days to see how it does. I need to get a relay, switch, line, fittings & a dump valve, then I can finish it.
Toby
Old Sep 17, 2012 | 07:53 PM
  #115
twistedcherokee
Road to work today, just have the air lines going to a tee since I don't have the relay, switch, dump valve & fittings, running 60#. What a difference. The bumps that I was bottoming out on before with the stock air shocks at max air (maybe even more), bumps were still there but it was sooo much smoother. I am definitely going to be happy with this mod. Thanks for all the write ups & to all those who suggested it.
Toby
Old Sep 20, 2012 | 09:42 PM
  #116
thecort's Avatar
thecort
Ohlins #3,#3 rear shocks for sale. They came off my 2010 SG. They are barely broken in with only 1,100 miles. What a difference a great suspension came make! These are in perfect condition. I'm asking $650 + shipping. These cost $850 new.
Please PM me or email me for pics.
Thanks,
Paul
Old Oct 7, 2012 | 10:56 AM
  #117
twistedcherokee
Well I got a dump valve from a 1995 Lincoln Continental but the 5/32 line is too small & the 3/16 is too big so I modified the valve. So the dump valve works great but I have to find a leak, didn't have time too chase it until today. Will get pics later & check out the leak.
Toby
Old Oct 8, 2012 | 11:55 AM
  #118
Str33tgl1de
finally did mine over the weekend, i gotta say pretty straight forward rides real nice too i havent put a gauge to adjust while i ride and have some temporary fittings but i got it all in and its awesom to be able to slam it when you pull up somewhere.
Old Oct 10, 2012 | 05:52 PM
  #119
Str33tgl1de
my boy finally put the video on youtube so i thought i would share the link with you guys.
Old Oct 11, 2012 | 06:38 AM
  #120
coolerman69's Avatar
coolerman69
http://www.youtube.com/watch?v=xEHMt...re=context-cha
Judging by the switch location you don't plan on many adjustments on the fly!
