will i need a tuner
Old Dec 20, 2011 | 01:03 PM
57red's Avatar
57red
Default will i need a tuner
gonna purchase a set of classic dual rinehart's for my 11 SG, is a tuner and an AC a must or will i be ok with just exhaust?
Old Dec 20, 2011 | 01:06 PM
mkguitar's Avatar
mkguitar
You'll be OK.
how ever to see any performance benefit, then you should think about a hi flow air cleaner.
Ness big sucker is the best bang for buck and an easy, tidy install.
ebay from easternpc, I paid $115 shipped
at that point you'd need to wade into the world of tuning compensation- I use nightrider.com XIEDS ( $125)
there are more interesting, complicated and expensive devices available. sometimes that complexity doesn't work for you
...and many riders remove the catalytic convertor in the headers, or replace with aftermarket headers
mike
Old Dec 20, 2011 | 01:08 PM
Ronp42's Avatar
Ronp42
Account Retired
If your bike is stock and this is all you want to do, you don't need a Tuner. Truth is if you wanted to do slipon's and A/C, as long as you don't remove the Catalytic converter, you still wouldn't need a Tuner.
Old Dec 20, 2011 | 01:09 PM
Iceman24's Avatar
Iceman24
For TD's - tuner would be my recommendation so you can adjust for the exhaust UG, but A/C is optional. Will make future upgrade adjustments easier too - add it to the XMas list...
Old Dec 20, 2011 | 02:53 PM
Biggzed's Avatar
Biggzed
Even a bone stock bike will always benefit from a good tune. The factory tune leaves a lot to be desired.
Zach
Old Dec 20, 2011 | 03:33 PM
hougz79's Avatar
hougz79
As stated, if you are doing JUST pipes, you should be fine, but not running anywhere near optimal. If it were me, I would look at getting a tuner eventually.
Also, you'll need to "define" your future plans for the bike. If you even remotely are thinking down the road of adding cams in addition to a Stage I, then definitely get a tuner. If you go the cheap route and get XIEDs or a flash download from the HD Dealer, you'll still need a tuner down the road when you do cams. In that case, you would have wasted $150.
Sometimes in the long run it costs less to spend more the first time.
Enjoy the ride. Rineharts are very nice sounding pipes.
Old Dec 20, 2011 | 05:01 PM
57red's Avatar
57red
A tuner it is then, just didn't know if it would make a difference with just the pipes so I'll order that too. Don't plan on doing anymore engine mods besides a new AC but plans always change!
Old Dec 20, 2011 | 05:06 PM
JetD's Avatar
JetD
Default Agree with Mike
Mike gave you good advice; and as another posted, your best results, regardless of what changes you make, will come with a good tune.... but, if you're happy with the way it runs, just run it and smile....
Oh, and by the way, you are about to become an addict to one degree or another... the sooner you recognize that fact and decide to what degree addict you will be, the sooner you will be able to control the addiction!!
Good luck and ride safe.
TORQUEY's Avatar
TORQUEY
Big Sucker intake, Full set of new 2-1 pipes, No cats, No tuner. Plenty more power, much less heat.
There's a great article in January's American Iron regarding certain "myths".
Old Dec 20, 2011 | 05:20 PM
Mr HOG's Avatar
Mr HOG
IMO, once you start changing the exhaust you might as well invest the money to make it right. For these new bikes that means getting rid of the cats, high flow exhaust and AC, and a new tune. If you know someone that can weld you can cut the cats out and use the stock headpipes. I would also recommend the Vance and Hines Fuel Pak. I know a few guys running it with stage one and very happy with results.
Webbie
General Topics/Tech Tips
Apr 1, 2017 03:20 AM
The Korean
Jun 10, 2013 08:35 PM
bucknit21
Apr 22, 2013 12:20 AM
bmn3907
Exhaust System Topics
Feb 8, 2013 05:44 PM
PDDGM
Nov 29, 2010 09:21 AM
