Another cam thread
Old Feb 15, 2012 | 09:01 PM
  #41
lionsm13's Avatar
lionsm13
Thanx for the update, been sittin' on the edge of my seat...
Old Feb 15, 2012 | 10:13 PM
  #42
BackRoader's Avatar
BackRoader
Added an Andrews 21 last summer. I love it. A little bit of extra pull. Key words here are "little bit". Cam change is a nice extra bump in power, but it does not turn your bike into a beast. Just a little extra pulling power, so don't expect huge gains here. As they say, "there's no replacement for displacement".
Old Feb 16, 2012 | 06:03 AM
  #43
tx-skydiver's Avatar
tx-skydiver
I know, right? I'm sure everyone was. Consider this my public service for the day.
Old Feb 16, 2012 | 07:56 AM
  #44
weride7/7's Avatar
weride7/7
255's here. Very adequate and reliable.
Old Feb 16, 2012 | 08:11 AM
  #45
Sash302's Avatar
Sash302
I vote for SE-204 great little cam
Old Feb 16, 2012 | 09:49 AM
  #46
drew4jan's Avatar
drew4jan
I have a set of SE255's sitting in the garage. Just waiting for push rods and gasket kit to get started.
Old Feb 16, 2012 | 05:22 PM
  #47
tx-skydiver
Thats actually what I meant. I think I typed 254 by accident.
Old Feb 16, 2012 | 06:45 PM
  #48
ocezam's Avatar
ocezam
Well if your talking a stock 88", like your sig suggests, then yeah the performance boost of a cam upgrade will be negligible. But on a 96" or better yet a 103", the performance gain is MUCH more noticeable.
The difference really isn't the 8 and 7 cubic inch bump. It's the compression difference between the engines. I believe a stock 88" has 9:1 compression, the 96" has 9.2:1 compression, and the 103" has 9.6:1 compression. Not huge differences, but it does make a pretty big difference filling the cylinders, and maintaining compression with more valve overlap. Therefore you can run a hotter cam and still have good low end torque.
Further, '07 and up cylinder heads flow a bit better than earlier Twin Cam heads and '07 and up stock cams are actually worse than '06 and earlier with less duration and lift.
All of these differences make a cam change in an '07 and up bike quite a bit more dramatic than earlier bikes.
Old Feb 16, 2012 | 07:26 PM
  #49
mtclassic's Avatar
mtclassic
I ran 21's in 88 and 95" and I personally would not run them in a 103.
Old Feb 16, 2012 | 10:22 PM
  #50
tx-skydiver
Originally Posted by ocezam
Well if your talking a stock 88", like your sig suggests, then yeah the performance boost of a cam upgrade will be negligible. But on a 96" or better yet a 103", the performance gain is MUCH more noticeable..
I'm not sure how my signature suggests that I am running a stock 88. Its a 2011 Ultra Ltd which came standard with a 103.
