More brake issues
Old Dec 29, 2011 | 05:04 PM
luisan's Avatar
luisan
That's the reason why I always have a mechanic perform the job.My life,and that of others,depend on brakes working properly.
Old Dec 30, 2011 | 07:11 AM
smokindave's Avatar
smokindave
When you push the pistons back in without removing the cover, you create pressure in the master cylinder and this doesn't allow the fluid to go back up to the master cylinder. Hence there is increased pressure in the line forcing the pads tighter. Always remove the master cylinder cap and you will have no problems.
Old Dec 30, 2011 | 08:03 AM
shore's Avatar
shore
I think the cap thing is what it was, also. The rubber seal was all out of wack in there so it had some pressure that needed to be equalized.
Old Dec 30, 2011 | 08:28 AM
robbie52's Avatar
robbie52
Always a lot of good help on this site, ut you need to get a manual.
craigthecarpenter
Feb 26, 2018 06:31 AM
SoaringAgain
Shovelhead
Mar 29, 2017 09:09 PM
wscott
Aug 24, 2016 08:42 AM
EasTexUltra12
Jun 23, 2015 04:05 PM
SpinnrUp
Jan 21, 2012 01:59 AM
